Looking to get a speaker amplifier for around $300 to power monitor audio rs1 silver
Solved by saintlouisbagels,
9 minutes ago, LAYTOR said:Alright, I will try to compare LOXJIE A30, with audioengin n22 gen2 then and if audioengin n22 gen2 will be worst I will just buy LOXJIE A30 thanks! The reason why I want to go with audioengin n22 as of now is purely because it has nicer connectivity options.
If you really want a pretty piece of tech on your desk, I love the way the WiiM amp looks
https://www.amazon.com/dp/B0CLGMPMFN/
I would pair it with the Apple USB-C dongle as well and then run a 3.5mm to 2x RCA cable.
