Building a computer, what should i do for sound?
Vicente Gomez
@Lays
the blue snow ball is a microphone and a speaker or just a microphone
Mic.
what do you think of the g230s tho
Most here are running Mid to High End headphones and desktop mics or some sort of clip on be it zalman or modmic.  I like audio company headsets or Headphones with detachable mics.
overall the G230 is  meh IMO.  the HyperX Cloud seem the best headset I can think of in your price range.
@Lays
what about speakers, when i build my pc, will there be built in sound, will it be enough?
here is my build
http://pcpartpicker.com/p/3QY1u
How much can you spend on speakers?
Why would you say that? Those are usually overpriced peieces of garbage according to Linus.
My AX pro's broke in under 6 months.
IMHO this is the worst option by far.
But hey it's your opinion.
What's up with my weird spacing?
I would say that because I think it's the better option.
It doesn't cost that much more to get a headset with a mic compared to a headset without one. Also I hate having to have an external mic sitting on my table. I'd much rather just get a headset.
Cpu: Intel i5- 4570 | Ram: Crucial DDR3 8GB | Video Card: Evega GTX 660 Ti 2GB Super Clocked
Monitor: Philips 24" | Keyboard: CM Storm Quickfire TK | Mouse: Logitech G700s |
Steam
No more than 100
@Lays
CHC silverados and a modmic are what I recommend if you want headphones and a mic
Pioneer SP-BS21-LR and a Lepai 2020A+ amp is what I would recommend for a speaker set.
you're sacrificing sound quality everywhere most likely. Especially at 100 bucks.
PC: 4770K @ 4.0 GHz --- Maximus VI Hero --- 8 GB 2133 MHz Corsair Vengeance Pro --- EVGA 780 TI Classified @ 1300 MHz --- Samsung Evo 250 GB --- Corsair RM 750 --- Corsair Carbide Air 540 --- CM Storm Rapid-I (MX Blues with PMK Evergreen Keycaps) --- Windows XP --- Razer Naga --- Custom Loop Parts: 380I, EKWB 780 Classy Waterblock and Backplate, 240mm and 360mm XT45, Swiftech MCP655, EKWB multi option reservoir, Mayhems Pastel Red, Primochill Primoflex Advanced Clear Tubing, 5 SP 120 Quiet Editions --- Mobile: Surface Pro 3 (i5 128gb) with JD40 (MX Clears) and Microsoft Sculpt Mouse --- Galaxy S6
