I don't have Wifi and Bluetooth
So I have the MSI B550 Pro Vdh Wifi motherboard and it seems like it can't connect to wifi. I have the two antennas built in and the drivers from the msi page (AMD Intel WIFI driver from the LAN section drivers and AMD chipset drivers from the System and Chipset Drivers). Is this a hardware failure? When I'm in device manager, in the section network adapters, I don't see the antennas, and in Window I only see the possibility to connect to ethernet.
Enter BIOS and look for/enable it?
ad infinitum
Do you know where I can find it in the BIOS? I'm kinda lost.
in the "onboard devices" settings
reset network settings and use troubleshooting for internet
update bios
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
Share screenshot of your Device Manager?
update bios
When I went into bios these were the settings
1 minute ago, KevenZimin said:
-snip-
It's there, only need driver.
Now right click on Network Controller, go to Detail tab and select HardwareID from the drop down menu.
Whats the value?
4 minutes ago, KevenZimin said:
no drivers
Whats the value?
Whats the value?
8 minutes ago, KevenZimin said:
-snip-
That's MediaTek, try update via Windows Update.
Oh wait.. It's packaged with AMD driver. Did you installed it properly previously?
https://download.msi.com/dvr_exe/mb/amd_wifi_driver.zip
https://download.msi.com/dvr_exe/mb/amd_bt_driver.zip
Please click the "Thumbs Up" on any volunteer's post to thank them if they helped .(lower left, just to the right of My Computer )
