PC Issues - Crashing - IRQ_NOT_LESS
pr0xibus
Afternoon folks.
CPU - Ryzen 5 3400G
RAM - 16GB DDR4
GPU - GTX 980TI
PSU - 550W
A friends computer is actually acting weird.  He has 2 games he really only plays Football Manager 2022 and Sims 4, every now and then the games crash with the error IRQ not Less or Equals.
Anyway, Things I have done/tried
Ran Memtest86 overnight - No issues, and a nice Pass
Ran Prim95 for 5 hours, again no issues at all.
Ran Heavin benchmark over 10 times, no issues.
Ran Furmark for 3 hours, no Issues.
Bios updated to latest update
Took the GPU out and gave it to my son to use on his games and his PC, after 12 hours no issue.
Swapped the RAM with my Sons PC and again no issues with my son using it.
I am unsure where else to look for this issue.  I have upgraded him from Windows 10 -> 11 and the issue persists.
Crashes only happen during gaming. and again not every time.
Sometimes they can go days/weeks with 0 crashes on Sims, then play it once and crashes 6 times in a row,
Same thing with Football Manager
The only thing I can think off is the GPU needs 650w, and its only a 550w PSU installed, but I expect that to crash the whole PC as in I.E. Turn off, as I have had an issue like that before.
Anyone have any ideas what to try?  Event Viewer is as useless as a chocolate teapot in this instance, and any Minidumps point to kernel.
Is this a game crash or a BSOD?
5950X/3080Ti primary rig  |  1920X/1070Ti Unraid for dockers  |  200TB TrueNAS w/ 1:1 backup
Go to C:\Windows\Minidump and check if you have any minidump files. If you do, go back to the Windows folder and copy the Minidump folder itself to the Downloads folder (You can use the desktop if you don't have OneDrive syncing files). Zip the copied folder and attach it to a post. Please follow the instructions to the letter as Windows doesn't like you messing with files in this location.
************* Preparing the environment for Debugger Extensions Gallery repositories **************
   ExtensionRepository : Implicit
   UseExperimentalFeatureForNugetShare : true
   AllowNugetExeUpdate : true
   NonInteractiveNuget : true
   AllowNugetMSCredentialProviderInstall : true
   AllowParallelInitializationOfLocalRepositories : true
   EnableRedirectToV8JsProvider : false
   -- Configuring repositories
      ----> Repository : LocalInstalled, Enabled: true
      ----> Repository : UserExtensions, Enabled: true
>>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds
************* Waiting for Debugger Extensions Gallery to Initialize **************
>>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.016 seconds
   ----> Repository : UserExtensions, Enabled: true, Packages count: 0
   ----> Repository : LocalInstalled, Enabled: true, Packages count: 41
Microsoft (R) Windows Debugger Version 10.0.27553.1004 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Users\natha\Desktop\051524-4984-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       srv*
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 22621 MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Kernel base = 0xfffff805`7d800000 PsLoadedModuleList = 0xfffff805`7e413110
Debug session time: Wed May 15 20:41:16.870 2024 (UTC + 1:00)
System Uptime: 0 days 0:18:54.520
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 000000a6`5460f018).  Type ".hh dbgerr001" for details
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff805`7dc183e0 48894c2408      mov     qword ptr [rsp+8],rcx ss:0018:ffffec02`40cbbd70=000000000000001a
7: kd> !analyze -v
*                        Bugcheck Analysis                                    *
MEMORY_MANAGEMENT (1a)
    # Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000000403, The subtype of the BugCheck.
Arg2: fffff400d3ec9240
Arg3: 8100000354a58c66
Arg4: fffff400d33c9240
Debugging Details:
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 1187
    Key  : Analysis.Elapsed.mSec
    Value: 1394
    Key  : Analysis.IO.Other.Mb
    Value: 0
    Key  : Analysis.IO.Read.Mb
    Value: 0
    Key  : Analysis.IO.Write.Mb
    Value: 0
    Key  : Analysis.Init.CPU.mSec
    Value: 202
    Key  : Analysis.Init.Elapsed.mSec
    Value: 3789
    Key  : Analysis.Memory.CommitPeak.Mb
    Value: 96
    Key  : Bugcheck.Code.LegacyAPI
    Value: 0x1a
    Key  : Bugcheck.Code.TargetModel
    Value: 0x1a
    Key  : Dump.Attributes.AsUlong
    Value: 1008
    Key  : Dump.Attributes.DiagDataWrittenToHeader
    Value: 1
    Key  : Dump.Attributes.ErrorCode
    Value: 0
    Key  : Dump.Attributes.KernelGeneratedTriageDump
    Value: 1
    Key  : Dump.Attributes.LastLine
    Value: Dump completed successfully.
    Key  : Dump.Attributes.ProgressPercentage
    Value: 0
    Key  : Failure.Bucket
    Value: 0x1a_403_nt!MiDeleteClusterPage
    Key  : Failure.Hash
    Value: {f401e11c-900d-f6cd-c291-93cf0151a773}
BUGCHECK_CODE:  1a
BUGCHECK_P1: 403
BUGCHECK_P2: fffff400d3ec9240
BUGCHECK_P3: 8100000354a58c66
BUGCHECK_P4: fffff400d33c9240
FILE_IN_CAB:  051524-4984-01.dmp
DUMP_FILE_ATTRIBUTES: 0x1008
  Kernel Generated Triage Dump
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  TiWorker.exe
STACK_TEXT:
ffffec02`40cbbd68 fffff805`7dcc6770     : 00000000`0000001a 00000000`00000403 fffff400`d3ec9240 81000003`54a58c66 : nt!KeBugCheckEx
ffffec02`40cbbd70 fffff805`7db3eede     : 00000000`0036b884 fffff805`7db10cad 00000000`00354a50 000001a7`00000001 : nt!MiDeleteClusterPage+0x186ee0
ffffec02`40cbbf60 fffff805`7db104c8     : fffff400`d3eca000 ffffec02`40cbc560 fffff400`d3ec9ff8 ffffec02`40cbc560 : nt!MiDeletePteRun+0x77e
ffffec02`40cbc150 fffff805`7daf39b9     : ffffec02`40cbc560 fffff400`d3ec9ff8 00000000`00000000 ffff8307`f5de6740 : nt!MiDeleteVaTail+0x48
ffffec02`40cbc180 fffff805`7daf3afa     : ffffec02`00000000 ffff8307`f5de6740 fffff47a`00000000 ffffec02`40cbc5b0 : nt!MiWalkPageTablesRecursively+0x4e9
ffffec02`40cbc210 fffff805`7daf3afa     : ffffec02`40cbc560 ffff8307`f5de6740 fffff47a`00000000 ffffec02`40cbc5c0 : nt!MiWalkPageTablesRecursively+0x62a
ffffec02`40cbc2a0 fffff805`7daf3afa     : ffffec02`40cbc560 ffff8307`f5de6740 fffff47a`00000000 ffffec02`40cbc5d0 : nt!MiWalkPageTablesRecursively+0x62a
ffffec02`40cbc330 fffff805`7daf33d1     : ffff8307`f90c3950 ffff8307`f5de6740 00000000`00000000 ffffec02`40cbc5e0 : nt!MiWalkPageTablesRecursively+0x62a
ffffec02`40cbc3c0 fffff805`7db11882     : ffffec02`40cbc560 00000000`00000001 00000000`00000002 00000000`00000000 : nt!MiWalkPageTables+0x371
ffffec02`40cbc4c0 fffff805`7db20e4e     : ffff8307`f5de6590 ffff8307`f13f4080 ffffec02`40cbc860 ffff8307`f13f4780 : nt!MiDeletePagablePteRange+0x3c2
ffffec02`40cbc7d0 fffff805`7df88497     : 00000000`00000000 fffff805`00000001 00000000`00000001 ffffec02`40cbc948 : nt!MiDeleteVirtualAddresses+0x4e
ffffec02`40cbc820 fffff805`7da7a697     : 000001a7`d9020000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!MiDeleteVad+0x1b7
ffffec02`40cbc8e0 fffff805`7dfa0bb0     : 00000000`00000000 00000000`00000000 ffffec02`40cbca40 ffff8307`00000000 : nt!MiFreeVadRange+0xa3
ffffec02`40cbc940 fffff805`7dfa07c5     : 000000a6`5497a148 00000000`00000001 000000a6`5497a6e0 000001a7`d9020040 : nt!MmFreeVirtualMemory+0x3b0
ffffec02`40cbca80 fffff805`7dc2d938     : ffff8307`f13f4080 000001a7`da4a0b40 00000000`000034a0 000001a7`df490080 : nt!NtFreeVirtualMemory+0x95
ffffec02`40cbcae0 00007ffb`85d4f724     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x28
000000a6`5497a598 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffb`85d4f724
SYMBOL_NAME:  nt!MiDeleteClusterPage+186ee0
MODULE_NAME: nt
IMAGE_VERSION:  10.0.22621.3447
STACK_COMMAND:  .cxr; .ecxr ; kb
IMAGE_NAME:  ntkrnlmp.exe
BUCKET_ID_FUNC_OFFSET:  186ee0
FAILURE_BUCKET_ID:  0x1a_403_nt!MiDeleteClusterPage
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {f401e11c-900d-f6cd-c291-93cf0151a773}
Followup:     MachineOwner
