PC making weird noise.
Janxski
My PC has been making this annoying noise for the past month and I cant figure out what it is. Its been driving me insane the last week. All ive done to the pc recently was upgrade the cpu and before the upgrade it wasnt making this noise. https://streamable.com/k0bmhw. There hasnt been any issues with temps/performance, The noise has been on and off, like a week itll constantly make this sound then the next week its quiet.
5800x3d
NZXT Kraken X63
B550M Aorus Pro
ROG Strix 3060
Supernova 750GT
If I had to take a wild guess...
I'm assuming you have case fans. Fan issue?
How silly of me, the radiator would have fans too.
It's pretty high pitched, so I'd think something rotating fast. Double check to see if anything ended up too close to the fans. It could be a fan bearing, or just something rubbing one of them.
It's also possible that air got trapped in the AIO pump, but I don't have firsthand experience with watercooling.
Seems like some type of coil whine from the motherboard?
Or maybe the pump of the AIO?
Really odd tho.
