Q-led d-ram always on | no post
My build:
  • Mobo: Asus Rog Strix B550-F Gaming WiFi II
  • CPU: Ryzen 7 5800X
  • RAM: Corsair Vengeance RGB Pro SL 32GB (2x16gb) 3600mHz C18
  • GPU: RTX 3070 Ventus 3x
  • PSU:Corsair RM850
HI, I still don’t know what really happened, it seemed like a power surge or an outage. As the title of the post says, I’m encountering a problem with my build, the q-led for the d-ram (most of the times, when I power on my pc stays on without post, and sometimes it goes from orange (d-ram), red (cpu) and stays on white (vga) always without post [this happens only with one slot of ram].
Searching on the internet, I tried everything that I could try, here’s a list of what I did:
  • Removed and re-connected all the cables;
  • Removed and reconnected all the parts;
  • Removed the battery of the mobo;
  • Started without the battery;
  • Changed the battery;
  • Reset the CMOS;
  • Updated the bios through the bios flashback;
  • Started the pc with only one slot of ram (it I power it on and off continuously sometimes it pass the orange q-led, but still no post, going into the red q-led and then the white one, but still, again, no post.
  • It could also happen that sometime, when both rams are installed, it goes from orange to red and then all the q-leds turns off and doesn’t boot.
With all those things nothing gave me a screen boot, always no signal on the monitor.
