Upgrading existing PC, keeping same motherboard
Budget (including currency): $AUD 1500-2000
Country: Australia
Games, programs or workloads that it will be used for: World of Warcraft, GTA 5 (6 when it comes out), Elden Ring,
I am looking to upgrade my existing PC, I'd prefer to not have to change the motherboard and existing SSD's and HDD's.
Old parts: GTX 1070, i5 9600K, 16GB memory.
I was planning to reuse my ASRock Z390 Pro4 ATX LGA1151 motherboard, 500gb Samsung 850 EVO boot drive, Samsung 840 Pro series SSD, NVME Samsung 970 SSD, 2 random 2TB HDD's, and my old Noctua CPU cooler (I think it's the NH-D14)
I was planning on buying an i7-8700K cpu, Corsair Vengeance LPX 32GB (2x16GB) DDR4 3600 CL18 memory, Samsung Pro 2TB M.2 2280 SSD, and a PNY 4070 Super 12GB video card. I realise I won't have room for a second M.2 drive, so I was also planning on getting a PCI expansion card to accommodate it.
Any suggestions would be greatly appreciated.
for the money you are spending, you are better off selling your old motherboard, cpu, ram and getting all new with ddr5 ram and modern features
9th gen intel is quite dated now, we are up to 14th gen with significant improvements in performance
not to mention your cpu has 16 pcie lanes (so does all of 9th gen), this means currently you're nvme drive is using 4, leaving 12 but unfortunately your gpu can only use 8 (just how it works), when you upgrade that it will  decrease performance of a new gpu essentially wasting your money as new gpus are very bandwidth hungry
Furthermore you will have 0 warranty on anything 9th gen as it is all old
Recommendation:
Sell Gpu, CPU, Ram, Motherboard
Get a new GPU, CPU, Ram, Motherboard
you will not bottleneck your gpu as you will have enough pcie lanes and will get significant performance uplift from the newer tech
Country: Australia
Yeah, you can do a lot more with that price point than buying a new cpu for a dead platform, buying a new gpu (which is basically all you can do if youre keeping everything and RAM is cheap) youll be cpu bound for a lot of things, id drop the 4070S and go for a 4070 or 7800xt and get a new mobo and cpu and you wont need to get a pcie expansion card either so put that back into the budget for core components
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Will I be able to just straight swap my old boot drive and ssd's to a new mobo with no fuss?
I basically want to upgrade without having to reinstall everything, with minimal downtime.
if youre getting a new cpu or sometimes gpu we'd generally recommend fresh installing windows (if thats what you use) regardless as itll make things run smoother, but you should be able to short term yeah
Basically when intel upgrades a socket theres a big generational leap, and the z390 chipset socket is 2 generations behind, intels next cpus will make it 3 gens behind, currently the lowest tier i3 14th gen, the 14100, is better than the highest tier i5 9th gen you have, the 9600K
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Maybe the best option for you is move important files or applications off the boot drive and get another drive to install windows.
You could prepare the new drive by installing it in the old system and installing a clean version of windows but you don't want any of the drivers or random items in your old boot drive as these can cause issues with the new hardware.
For your cooler, remember to get the new mounting system if you go with that route.
A CPU upgrade is a good idea tho with your budget
Alright cheers, I'll do some research and start a new topic with a new build.
Are there any suggestions on motherboards to get me started?
