Does a rtx 3070 work well with a amd ryzen 5 7600? Or should i get a different CPU? (And any Upgrade Suggestions for my pcbuild)
Go to solution Solved by DoctorNick,
22 minutes ago, Xozeyn said:
Im from germany
PCPartPicker Part List: https://de.pcpartpicker.com/list/hCHFMV
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (€197.00 @ Mindfactory)
Motherboard: Gigabyte B650 GAMING X AX ATX AM5 Motherboard  (€181.55 @ Galaxus)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (€126.89 @ Alternate)
Storage: Kingston NV2 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€63.90 @ Galaxus)
Video Card: MSI VENTUS 2X BLACK OC GeForce RTX 4060 8 GB Video Card  (€315.00 @ Galaxus)
Case: Phanteks XT PRO ATX Mid Tower Case  (€59.90 @ Amazon Deutschland)
Power Supply: EVGA 650 BQ 650 W 80+ Bronze Certified Semi-modular ATX Power Supply  (€66.90 @ Alza)
Total: €1011.14
Generated by PCPartPicker 2024-03-05 12:59 CET+0100
If you can get a 3070 for cheaper, that would be good. CPU includes stock cooler, you can upgrade later.
Budget (including currency): 1000€ (for the whole pc)
Country:
Games, programs or workloads that it will be used for: fortnite, red dead redemption, overwatch etc
Here is my whole build: https://pcpartpicker.com/list/ ( its going to be my First Gaming pc)
Country:
Do you already have a 3070? Yes it works well, also if you're thinking of using parts from the prebuilt, then post specs
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15 with one fan
FS in Denmark/EU:
Asus Dual GTX 1060 3GB. Used maximum 4 months total. Looks like new. Card never opened. Give me a price.
No i dont have anything bought yet and im Building it by myself. You can See the Parts that i will probably use on the link from pc Part Picker
And do u have any suggestions on something which i can Upgrade?
And its no prebuilt
5 minutes ago, Xozeyn said:
And its no prebuilt
Roger, where are you located? You say 1000 euros
FS in Denmark/EU:
Im from germany
Im from germany
Total: €1011.14
FS in Denmark/EU:
Total: €1011.14
 Thank you sm! Im think im Buying the rtx 3070 Used for about 300€, do you think that the Gigabyte Version is good? Because i heard that the 4060 is Worse that the 3070
Total: €1011.14
But do you think that i can still buy the h9 Flow case, because i really like how it looks
4060 is both lower performance and lower VRAM, and 300 is a decent price for the 3070, but youll be losing out on the warranty and security buying new provides (but personally at that price id take the 3070)
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
what do you think about the h6 flow?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Its also good but doesnt have pre installed Fans so it would be about an extra 50€
Do you think its better that the h9?
Total: €1011.14
I have one last question: in your Build you recommended the evga 650 as a psu for 66€ but in my previous build i had an apevia prestige with 150 more watt and also Gold certified and also 66€. So should i buy the apevia or the evga psu?
Like @TatamiMattmentioned, there's always a chance of the GPU going bad, but i'll say go for it. Gigabyte Vision? https://www.gigabyte.com/Graphics-Card/GV-N307TVISION-OC-8GD#kf
Yes that's an awesome card! H9 flow should be good as well, but is more pricey
FS in Denmark/EU:
PSUs are kind of funny, they have rating and this and that but no way to quantify quality of the components inside other than what they may or may not promise, generally refer to the PSU tierlist for this as people have done extensive testing on PSU quality, see below
https://cultists.network/140/psu-tier-list/
Im not sure if its cheaper for you but generally its quite a bit cheaper and it should come with 3 fans preinstalled
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
The apevia prestige is in Tier c, is that ok? Should i buy more Fans because i think that 3 Fans are to less or am i wrong?
Tier C is a little low but its fine, also speculative position so a little lower again, generally if you want a build about $1000 plus youll want Tier B or higher
3 fans for which case?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
So should i get the evga or the apevia psu?
you Said there were 3 pre installed Fans for the h6 Flow, but do you think i should buy more?
There's space for 3 more in the bottom and one in the rear, i think the 3 will be fine.
If you wanted to make it look filled out you could buy more. Ive had my current PC for almost 5 months now and im slowly filling out the fan slots when i have some spare change, bought my last 3 pack there not too long ago.
You could do something similar if you want to spend the money for those fans on the pc components right now and add other fans later. the 3 fans that come installed should be plenty for cooling though
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
I would recommend the EVGA. Also I know its good because I experienced it survive almost a nuclear explosion. Had it in my brothers old PC (my old build) with 4790K and GTX 780 SLI. He never cleaned the PC and at some point alot of dust was on top og the GPU's with smoking gue and what not. I warned him multiple times that it would kill the PC. And it did, a GPU died. But motherboard and PSU survived.
FS in Denmark/EU:
Just now, TatamiMatt said:
There's space for 3 more in the bottom and one in the rear, i think the 3 will be fine, if you wanted to make it look filled out you could buy more. Ive had my current PC for almost 5 months now and im slowly filling out the fan slots when i have some spare change, bought my last 3 pack there not too long ago. You could do something similar if you want to spend the money for those fans on the pc components right now and add other fans later. the 3 fans that come installed should be plenty for cooling
Ok, do you have any recommendation for any 3 pack Fans that are Cheap but work well ( and also my pc build is going to be white so some white Fans with rgb would be awesome)
I think the white h6 flow comes in both white and with rgb fans if you get the right version, youll want a white argb 2 pack or 2 individual 140mm fans for the bottom, they sit perfectly in a recessed area to make the bottom entirely flush and 1 120mm in the rear. If youd like you can also add one to the top rear but thats not as needed (none of them are but if youre adding fans id prioritise those 3). The fans are essentially whatever your rgb and looks preference is, there are 2 things that affect performance, a fans CFM and static pressure, basically, how much air the fan can move (cfm) and how hard it pushes it (static pressure) for case fans these dont need to be particularly high
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Thanks! I looked the h6 Flow up and with rgb Fans it costs about 140€ and without 110€. The h9 Costs wirtout rgb 140€ so im considering buying the h6 with so thanks for the advice, also thanks to @DoctorNick for your advice and your Part list! 🙂
