5800X3D running hot and I'm out of ideas
Hi all,
I recently switched from a Ryzen 5 3600 to a Ryzen 7 5800X3D. It may be important to note that I initially upgraded from a 3600 & RTX 3070 to a 5800X3D and 7900 XT, and was running a stress test with Prime95 & Furmark at once on a 750W PSU. The computer immediately shut down, so I upgraded to a 1000W PSU and don't have this issue anymore. They both run fine at the same time (could this have damaged by CPU/motherboard causing this issue?).
I was idling fine on the 3600 around 35 C, but this 5800 idles around 65-70 C. I've asked around on Reddit and other forums and everyone seems to agree that these temps are way too high. From what other people post, I should be seeing around 30 to 40 C idling (when I say "idle", I mean with Discord, Steam, and HWiNFO open at once).
I've tried the following:
  • Disabled A-XMP in my BIOS (made no difference, so I turned it back on)
  • Updated my BIOS
  • Reset CMOS
  • Swapped out the kryosheet I re-used from my 3600 for a new one
  • Changing the cooler from a be quiet! Dark Rock Pro 3 to a DeepCool Assassin IV
  • Changing from a kryosheet to thermal paste
Nothing I've done has changed the temps and I'm completely lost at this point.
Here are my specs:
  • AMD Ryzen 7 5800X3D
  • 32 GB (4x8 GB) DDR4 3200 RAM (3200 w/ A-XMP on) (if the brand matters it's TEAM Group TFORCE)
  • MSI B450 Tomahawk (latest BIOS revision as of this post, not Tomahawk MAX)
  • AMD 7900 XT
  • Corsair RM1000E 1000W PSU
I'm using HWiNFO to read my temps, and reading the Tctl/Tdie temp. Screenshot
If anyone can point me in the right direction here as to what I'm doing wrong, I would GREATLY appreciate it. The only thing I haven't tried is reinstalling Windows, but I'm not sure how/why that would help.
Your temps are normal since this isn't idling.
What are load temps? Is the cpu throttling or are you encountering performance issues?
If I run Cinebench 2024 on a multi-core load, it maxes out at 83 C. I believe the max temp is 90 for this chip.
Is 70 C normal for having three programs open?
All of those are normal. If you aren't experiencing performance issues, don't worry about it.
the X3D runs hotter than the other chips. this is normal.
If you are worried, try setting a negative PBO offset, this should lower temps
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
