Pc build for Fortnite 240-360 fps on 1080p
Budget (including currency): 600 dollars
Country: Iran
Games, programs or workloads that it will be used for: Fortnite, Premiere
Other details : I have found a new 6800xt for 400 dollars which is amazing. So no need for the gpu. Plus the build should include a monitor.
I'm assuming the budget doesn't include the gpu? Don't want to disappoint you, but you aren't getting a pc + a 240Hz monitor for 600$, without monitor we can definitely make it work, but not with a good monitor
What about without monitor?
You can try to go for the 7500f with a b650 motherboard, but then you have to cheap out on other components, or buy used, which is a good idea at your remaining budget. Used RAM works exactly like new one, but costs less, used power supplies cost WAY less, but are still perfectly good. Only thing i wouldn't buy used is the SSD, because those do eventually fail after some time (way less than other components)
I must jump in to agree, such build would require some realistic expectations for budget, or use of second-hand parts on some components
maybe even getting a cheaper GPU, it depends
without monitor it starts to get realistic, but remember in US pricing cheapest 240Hz monitor is about 150$+
and a decent gaming monitor is like 100$ minimum, again in US pricing, your country's prices could be 0-20% more expensive
Feel free to ask any questions regarding my comments/build lists. I know a lot about PCs but not everything.
PC:
Ryzen 5 5600 |16GB DDR4 3200Mhz | B450 | GTX 1080 ti
PCs I used before:
Pentium G4500 | 4GB/8GB DDR4 2133Mhz | H110 | GTX 1050
Ryzen 3 1200 3,5Ghz / OC:4Ghz | 8GB DDR4 2133Mhz / 16GB 3200Mhz | B450 | GTX 1050
Ryzen 3 1200 3,5Ghz | 16GB 3200Mhz | B450 | GTX 1080 ti
One question. I don't know what power supply I should buy. What is gold, silver ? What does it even mean?
Everything is more expensive in my country except GPUs. They are at least 35% cheaper than the price in US.
Country: Iran
Best I could do was $740 with a monitor (without making the other components lower quality) Though AM5 is also possible (not in budget but not too far off 600)
PCPartPicker Part List
CPU: Intel Core i5-12600KF 3.7 GHz 10-Core Processor  ($160.99 @ Newegg)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: ASRock Z690 Extreme ATX LGA1700 Motherboard  ($129.99 @ Newegg)
Memory: Silicon Power GAMING 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($34.97 @ Amazon)
Storage: Mushkin Helix-L 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($59.99 @ Newegg)
Case: Fractal Design Pop Air ATX Mid Tower Case  ($59.99 @ B&H)
Power Supply: Thermaltake Smart BM3 850 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($79.98 @ Amazon)
Monitor: AOC 27G2Z 27.0" 1920 x 1080 240 Hz Monitor  ($174.43 @ Amazon)
Total: $736.24
Generated by PCPartPicker 2024-03-03 04:58 EST-0500
CPU Cooler: *Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($33.90 @ Amazon)
Motherboard: *ASRock B650M-HDV/M.2 Micro ATX AM5 Motherboard  ($119.99 @ Amazon)
Memory: *Silicon Power XPOWER Zenith Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($92.97 @ B&H)
Power Supply: *MSI MAG A650BN 650 W 80+ Bronze Certified ATX Power Supply  ($59.99 @ Amazon)
Custom: 7500F ($155.00)
Total: $756.26
Generated by PCPartPicker 2024-03-03 05:02 EST-0500
this is efficiency. Doesn’t matter that much. Try and find a unit which is tier C and above. Use cultists network psu tier list and CTRL F
1 minute ago, podkall said:
also how important is getting to 240+fps? because without a 240hz monitor you're not really going to see much of it,
I would suggest that you could make a decent machine which is all-rounder solid for gaming, or Fortnite if that's your main game, and work from a build that maybe gets like close to 200fps on a good day and doesn't drop below like 150fps in demanding scenarios,
@artsInfinite this
if you get a 144hz or 165hz monitor you could shave the price down by 70 bucks
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
gold silver 80+ is efficiency, it doesn't really give any useful information because lot of PSUs already are 80%+ efficient, the certification is only for the purpose of being certified at that efficiency, quality is much more important
brand new?
how tight is your budget?
PC:
PCs I used before:
brand new?
I have a 165hz monitor right know. I can wait for a monitor but my pc is really weak so I'm just buying a good pc first then I can buy a decent monitor as well. The monitor is kinda optional right know.
The pc is ruining my work as well.
About prices. Yes all the brand new GPUs come with warranty as well. 6900 xt is like 500$.
Do you think a Ryzen 5 7600x is worth it at 183$? No cooler in the box though.
What ram would you say does the job and is worth it but not too expensive?
165hz is perfectly fine. You won’t feel the drop in latency or increased smoothness when going from 165hz to 240hz
Get the 7500f instead on Aliexpress for 155 and then get a PS120SE for about 35 and you get to the same price as the 7600x
Cheapest 6000 CL30 ram you can find (that isn’t high profile)
Current parts list
I found a 32GB one about 120$
I live in Iran. Can't buy anything from outside the country. Sanctions
I found a 32GB one about 14$
You found 32gb of ddr5 6000 CL30 for $14? Check it’s not a scam
Damn it
Current parts list
Sorry converted the currency wrong. 120$
Btw I found a 7500f in my own country. 146$. No cooler
That's literally cheaper than it costs for me in poland, a pretty good deal if you ask me. It would pair pretty well with AK620. You should look for used power supplies, like corsair rm750, this is a great power supply, and pretty cheap on the used market. To check if a psu is good, you should look at the psu tier list, and don't rlly go below C, even better if B
Found the 7500f for 146 but couldn't find this cooler. The PS120SE.
Found the AK620 for 90$
a bit more expensive than for me, you can look for peerless assasin 120 se if that's too expensive for you
Is there something like the ak400 or the thermalright Assassin X refined SE?
Current parts list
what about 5 7600, cheaper or more expensive?
how much for ARCTIC Freezer 34 eSports?
PC:
PCs I used before:
7600x and 7600 are about the same price here
Ok here's what we have put together right now:
Ryzen 5 7500f + Ak400(couldn't find any other one of the things mentioned): 178$
Rx 6800 xt : 395$
G.Skill 32GB 6000mhz cl30: 131$
Motherboard: undecided
Case: Undecided
Power supply: Undecided
The last 3 I have no idea what to get.
Found the ak400 for 33$
I mean compared to 7500F, I'm guessing the 7500F is cheaper then?
there's also AG400 it's almost as same as ak400 just looks different
Rx 6800 xt : 395$
isn't that already 600$?
PC:
PCs I used before:
