Budget pc parts picking help
Go to solution Solved by BiotechBen,
5 minutes ago, dabng said:
Budget (including currency): 1800 zł
Country: Poland
Games, programs or workloads that it will be used for: 1080p Gaming
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Willing to resort to used parts or sites like AliExpress
Hi, upgrading from a 4th gen i5 and a 750 ti here, I'm looking for a full budget gaming pc (case, gpu, mobo etc) for under 1800 zł, I can't decide on what I want so I'm asking for advice on what should I look for. Budget is not flexible at all, 1800 zł is a concrete barrier.
I would HIGHLY recommend looking in the local used market at your budget.
Look for something in the range of:
Zen 2-3 Ryzen €50-75
1660 super-2070 €100
750w gold PSU from a reputable brand €75
B450/550 board €50
500gb-1tb NEW SSD PCIE gen3 €50
16gb RAM €40
Any case that you can find €0-25
Total is about €400 which comes in just below your 1800 zł budget.
Country: Poland
Country: Poland
B450/550 board €50
16gb RAM €40
B450/550 board €50
16gb RAM €40
Thanks you!
