Help my ssd m2 is show 2 red light and not detected in bios
Popcorn4
I have i3 12100f ,motherboard asrock h610 m2/r2 and ssd m2 that seem to be sata as have 2 notchs. Is a new build but is not show in bios the ssd . When I check the ssd on motherboard is show 2 red light and is constant not blinking .....  what can I do ? Sorry if my English is not the best. Can someone pls help I really hope I can fix this as this is my first build not sure what is the issue
What's this SSD? It looks to be trying to fake a Samsung "1090 Pro" which doesn't exist. Probably a non-working scam.
F@H
GPD Win 2
From my quick research, that's an AliExpress special, and is some random sad with a sticker on it. The vast majority of m.2 slots are NVMe ONLY. And that appears to be a SATA drive. It will not work in an NVMe only slot. I'd be surprised if it works at all.
Yes I bought this from aliexpress.
The slot motherboard have is ultra m2 and I insert this sata ssd. Is this the issue should I use nvme?
I was thinking it will work as the red lights show. Is my first build and didn't know what to choose
Mobo supports both SATA and NVMe.
F@H
GPD Win 2
So then what can be the issue? Thanks
It may not work at all. It's a super AliExpress special SSD. I wouldn't be surprised if it was ewaste.
Ok I was thinking maybe should I update drivers of mobo but not sure. BTW I found this ssd nvme should I just buy this instead? I try to keep the budget low and this is what I found local
What is your budget, country, and how much does that cost?
I'm from România.  This is in usd 33$. I can go little bit higher but not much what do you recommend for storage to get the most of my configuration since the hardware is not the most performing : 12100f ,rx580 and 16gb ddr4 3200. I will plan to update in the future the cpu and gpu and maybe rams
