I need help with upgrading my setup.
Budget (including currency): 400 Euro
Country: Lithuania
Games, programs or workloads that it will be used for: All rounder, I stream, play games and do some work with unreal, blender and unity.
Other details: RTX 2060,  i5-9400F, MSI H310m pro-vd, 16gb ddr4 2133 MT/s.
Hello everyone, as you can see from my setup I'm not that good at picking part could you help me with a new motherboard and cpu. I was thinking about Z690-P and i5-12600k and when I get more finances to put in a M.2 ssd and in the end upgrading the RAM 3200 MT/s.
You could buy a Ryzen 7 5700x3d, that has huge performance boost in gaming but a little bit sacrificial on other non gaming app. But that's the "End" of AM4, that is why you could go on a AM5 Ryzen 5 7600x and later upgrade to a X3D down the road, because the AM5 Platform is still being updated and you can expect newer processors in the future.
AMD Ryzen 7 5700X3D | Gigabyte B550M DS3H Rev 1.7 | Kingston Fury X 32GB DDR4 (2X16) 2666MHz | Gigabyte RX 6800 GAMING OC 16G |
Thermalright Peerless Assassin 120 SE | 3X Rakk Maris Pro 120mm RGB Fans | Rakk Dulus Case | Gigabyte GP-P650G 650W 80+ GOLD Certified Active PFC
Lexar NM710 M.2 1TB NVMe SSD Gen 4 | Crucial MX500 500GB 3D NAND SATA
KOORUI 24E3. 24" 1080p Gaming Monitor, 165Hz Refresh Rate, IPS Panel
Ok, thanks I'll look into it.
I almost forgot my cpu fan is a stock intel one and i doubt that will be enough for either of those cpu's.
