AIO fitting on motherboard
Hey all,
I have maybe silly question about AIO fitting on motherboard, right now using EK-Nucleus AIO CR360 cooler on Asus ROG STRIX B650-A with Ryzen 7 7800X3D and temperatures are spiking, fans jumping from low speed to high if I turn on like chrome and steam, its annoying how fans behave, so my main question maybe I tight to much pump to CPU itself? Its holds with some a spring screws, howe much I need to tit it? In manual there is no mention at all.
Spring loaded screws are usually meant to be mounted as tight as possible, this behaviour could be caused by insufficient thermal paste application or because the pump is bad/plugged in wrong.
English is not my first language, so please excuse any confusion or misunderstandings on my end.
I like to edit my posts a lot.
F@H-Stats
The Folding rig:
CPU: Core i7 4790K
RAM: 16 8GB (2x4GB) DDR3-1600
GPU 1: RTX 2070 Super
GPU 2: GTX 1060 3GB
PSU: Gigabyte P450B EVGA 600BR EVGA 750BR
OS: Debian 12 (it works, or at least tries to [as of now, it's majorly broken])
Hi.
1 hour ago, greenmephisto said:
Hey all,
What's the CPU temp when spiking?
Ryzen tend to naturally jump to 60C ish at least for some time when doing anything, fan curve has to be stable and relatively low up to near 70C
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
Yeah, thinking maybe reapply thermal paste again, because pump seems works fine
