Gpu didn’t click in
Vex828
Is it okay that I didn’t hear my gpu like click in? It was a little wobbly so I bought a support bracket, everything turns on and it has a few frame drops in games, IMG_6076.thumb.jpeg.40fac35c075f4fbccbbb88d1f4dbb253.jpegnot too often. Gpu is rx 7800xt
did you make sure that the clip was open? sometime the click isn't that loud, it wasn't on my b550. But it was secure enough that I couldn't pull it out when it was in (that's what she s-)
It should be fine. What're your specs?
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
Some PCIe slot locks (which produce the "click") don't click, or you have to lock them yourself.
Generally, the lock doesn't have to be engaged if you never move the computer around.
If you want peace of mind, check the lock mechanism on the slot for if it's actually locked.
English is not my first language, so please excuse any confusion or misunderstandings on my end.
I like to edit my posts a lot.
F@H-Stats
The Folding rig:
CPU: Core i7 4790K
RAM: 16 8GB (2x4GB) DDR3-1600
GPU 1: RTX 2070 Super
GPU 2: GTX 1060 3GB
PSU: Gigabyte P450B EVGA 600BR EVGA 750BR
OS: Debian 12 (it works, or at least tries to [as of now, it's majorly broken])
Hi.
Didn't I ask you to move that white cable?  🙂
We don't need a pic though for this, just give it a little more push.  Some boards flex if you haven't done the standoffs correctly.  Could be just that.
What do you mean by frame drops?  Are you implying that since it's not clipped in, it's causing them?
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
What do you mean by frame drops?  Are you implying that since it's not clipped in, it's causing them? I did move it , just a slightly older picture, and I mean I don’t know, I tried pushing it in a little more but it’s probably fine
Most likely fine.  If it works, there is a connection.  Since you aren't moving your machine at all, it won't go anywhere.
I'd leave it them and enjoy.
OnePlus:
Other Tech:
Its a b650m-k by gigabyte and the gpu is the hellhounf 7800xt
I too would recommend routing that white cable better. Not critical but you're 90% of the way to a gorgeous build and a little extra effort can push you over the line.
I'm almost certain that you could route it through the hole in the top of the backplane then out through ideally the bottom right passthrough hole (just below the one with the 24pin mobo power). There are a couple other bits of cable management you could do if you want tips, but really, a very pretty build
5950X/3080Ti primary rig  |  1920X/1070Ti Unraid for dockers  |  200TB TrueNAS w/ 1:1 backup
I did do it, the picture is a little older
