CPU red light on (on the motherboard)
Posted (edited)
Hi,
one week ago my old computer started to keep restarting, tried everything but in the end I decided to replace the mo-bo + CPU + RAM.
The new components are:
Gigabyte Aorus B650 elite ax
Ryzen 7800X3D
Kingston DDR5 fury beast black
Put everything together, computer started without any issue and kept working for the whole week (I didn't do any benchmarks or tests though).
Today it suddenly doesn't start - when I push the start button the red CPU led on the motherboard immediately lights up and the computer does nothing (tried to run it like that for several minutes).
Tried to play with the RAMs, change PSU, reconnect all the cables, no luck so far.
Has anyone any idea what can be the issue? I would understand the fresh build, but this PC ran the whole week and there was no change! (well except for the Windows update)
Thanks in advance.
edit: when the computer's up, the power button does nothing, even after holding it for a minute, I have to switch off the PSU
Edited by jeff83
additional info
7 minutes ago, jeff83 said:
Hi,
Ryzen 7800X3D
Thanks in advance.
Reseating CPU might fix the issue
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
can't imagine that it would work one whole week if not properly seated...
Youre not wrong but if its a CPU issue currently it cant hurt to try
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
ok, I will give it a try
So, removed everything except for the CPU and one memory stick, still nothing.
Tried to reseat the CPU with no luck.
However I checked the AM5 slot and it seems to me like the pins are bent...
Could it be that I have tightened the CPU cooler too much and bent them? (I used an older one - Silentium Fera 3 HE1224).
They look fine
Hmmmm...pop the cpu back in there and let's see what else we can do
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
already done, nothing has changed 😞
Could try the cpu in a different mobo and/or try a different cou in that mobo if you are able to do that to rule the socket or the cpu out
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
So, bought a new CPU + mobo, put them into the case + 1 RAM stick and still the same problem ;-D
The only common thing is the PSU (but I tried an older one with the same result), the memory stick and the cables...
But I tried both mem sticks, it would be very weird if both sticks were damaged...
And the cables were re-plugged several times.
Well I guess I will buy new RAM and see if it fixes the issue 😕
SOLVED!
Just for future reference - I changed literally everything, only the case stayed, and the problem persisted...
So the I tried to unplug every single cable from the case except the one for the power button. And it started working again! After few tries I found out that the reset cable / button is somehow broken, so without it the PC is running without any issues!
Thanks anyway Tatami 🙂
