An overheating 2080 and second hand woes
hwg315
So I bought a second hand mini ITX pc with an RTX 2080 that's been regularly hitting worrying temps. When I first got it, hot spot temp would rocket to 107º under any gaming load and it would cut power (all info according to HWInfo). I did a repaste (which it sorely needed, the thermal paste was cake), but it is still hitting 100º on the hot spot even with a 70% power limit and some under-volting via MSI Afterburner. Is there anything else I can do or am I SOL? GPU performs fine for overwatch, but I'd like a bit more performance for Doom Eternal, Halo Infinite, etc. Attached is a screenshot of HWInfo during a FurMark run.
Do you have good case airflow? And what cpu and cooler are you using?
That seems quite high, especially for that fan speed
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Almost certain it’s not an airflow issue, but to answer your question it’s a cougar mini itx QBX case and I have an 8700k with a corsair 120mm AIO. I could try a test with the side panel off, but I doubt it would change anything. GPU should be drawing air direct from the outside through the bottom of the case as configured.
I mean, its worth a try i guess? could rule out a few things hopefully
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Running with no side panel didn't help with anything. Pinned at 100 degrees between 65 and 70 percent power in Overwatch. At this point, I'm at a loss for what to do.
