Why is my computer power LED blinking?
Hey guys
I noticed this month my power LED blinking in normal operation my motherboard is Asus PRIME Z690-P D4
specs: i5-13600KF, 32 GB RAM, 1080 TI and Hyte Y60.
I have contacted Asus support they have no idea why and they recommend disable LEDs in BIOS or disconnect the cable
they are sure really helpful 🤦‍♂️ in the last message they said I should ask support from Hyte about the issue lol
Typically this is part of the front panel connector and signifies hard drive activity. You can disable this by unplugging then HDD led front panel connectors.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
When does it start blinking like that?
  • 2 weeks later...
It happened a month ago found out I can put my PC in sleep and turn it again make the LED static again so weird
not in the hard drive pins I put it in PWR LED
sorry, I didn't get any email notification I guess I forgot to turn it on lol
