Display Card & Bios Woes (1070 in a AM3+ mobo wont display)
PlatinumSun
Go to solution Solved by PlatinumSun,
Problem solved.
I know the 1070 works as its from a friend and has been used it before. The CPU (FX-8350) works, machine posts, fans spin. Everything spins. Brand new top of the line ROG monitor is in working order.
So I put the machine together, it posts, peripherals light up, power button works, fan control button works (old case eh), reset button works. However for the life of me I can not get display. Despite the fact the GTX1070FE has its LED light up and the fan spins. No weird smells from running.
Anyways I tried every fitting PCIE slot and all 3 display ports and the HDMI port. (Not the DVI as I have no cable)
Windows is not installed, I just have an empty SSD hooked up.
So second time I power it up I noticed peripherals don't light up, and the reset button doesn't work. I am very confused.
GA-(990XA-UD3-rev-1.1 with an FX-8350.
GA-990XA-UD3-rev-1.1 with an FX-8350
https://www.gigabyte.com/Motherboard/GA-990XA-UD3-rev-1x#ov
https://download1.gigabyte.com/Files/Manual/mb_manual_ga-990xa-ud3_e.pdf
So I think the issue has something to do with UEFI vs legacy bios. Has an 8350 in it.
However the MOBO lacks a display port.
Would resetting the CMOS works?
This board is from 2011.
Are you sure it's not this?
https://www.nvidia.com/en-us/drivers/nv-uefi-update-x64/
AM3+ boards for FX support UEFI. The 1070 also does.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
