intel ax200 wifi 6 m.2 wifi card not working
I have recently moved house and ethernet is no longer an option for my pc so i bought the intel ax200 card(https://www.umart.com.au/product/intel-wi-fi-6-ax200-m-2-2230-gig-a-and-e-key-sockets-ax-bt-module-no-vpro-oem-brown-box-64837) to get working wifi for my system the card when first connected was able to sustain a connection but at very low speed, at least 10 times slower than the laptop sitting directly next to it, it is now no longer able to hold a connection at all and when it connects to any network it gets no access i was wondering what my next steps should be to try and fix this. i have so far, installed the generic intel drivers, uninstalled the device and restarted the system and as followed the changes to settings listed here https://community.intel.com/t5/Wireless/Intel-Wifi-6-ax200-Dropping-connection/m-p/665237 (
  • Change the channel width from "Auto" to "20 MHz"
  • Disable Fast BSS Transition Roaming)
Do you have the antennas for it?
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
1 minute ago, lachierules365 said:
it never came with any at all
Then thats your problem. You will need to buy them separately. There is 2 little snap on ports where the antennas go. Without them, this is why you're getting horrible wifi coverage/speeds.
"Black Out"
thanks for ur help sorry for the dumb question
No dumb questions, You're good.
"Black Out"
