Best monitor for Horizon Forbidden West PC?
King Minor
I am wanting to get a good monitor for horizon zero dawn. I want it to be 1440p (ultrawide if possible) and at least 120hz. I want good color accuracy. I won't pretend to know monitor specifics, so I can't really explain it. I prefer mesmerizing experiences to insane speeds.
I have been heavily considering this monitor, but it is on the top edge of what I can afford to pay (I would prefer around $200-225). Any monitor recommendations or things I should look for when buying?
2 minutes ago, King Minor said:
for me at least, this link just brings me back to this topic
MSI G272QPF 27.0" 2560 x 1440 170 Hz Monitor (G272QPF) - PCPartPicker
ViewSonic OMNI VX2728J-2K 27.0" 2560 x 1440 180 Hz Monitor (VX2728J-2K) - PCPartPicker
This one's on the edge but also includes a mouse with the purchase (which Newegg says is worth $40 but to me it looks more like $25, like G203 price)- Gigabyte G27Q 27.0" 2560 x 1440 144 Hz Monitor (G27Q) - PCPartPicker
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
I fixed the link, sorry about that. Thanks for the advice.
Looks OK but it's VA and as someone with two VA monitors, VA smearing is quite apparent on both. It should be better with higher refresh rate monitors (I've only got one 60hz and one 75hz) but i'd defo go for IPS
Current parts list
Ok, about what price range would the decent quality ultrawide monitors fall in?
Those start at around $270 for high refresh rate ones at 3440x1440 Acer AOPEN ‎34HC5CUR Pbmiiphx 34.0" 3440 x 1440 144 Hz Curved Monitor (UM.CW5AA.P02) - PCPartPicker
There is 2560x1080 for $210 that is high refresh rate but at 30 inches I believe the pixel density would be too bad at this size to be viable Sceptre C305B-200UN 30.0" 2560 x 1080 200 Hz Curved Monitor (C305B-200UN) - PCPartPicker
it does have good ratings though and is easier to run than 3440x1440 so make of that what you will
Current parts list
1 hour ago, King Minor said:
this is the best 1440p monitor for around 200usd
http://tinyurl.com/mj6tfvej
for ultrawide at that price range, it's all similar VA panels so you are paying extra just for the uw in exchange for color/picture quality compared to the original AOC you linked.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Thanks for the recomendation, but it was a bit more expensive when I looked at it. Closer to $245
ye I clicked the link and it's $300?
Current parts list
12 hours ago, King Minor said:
theres a coupon and a prime price, 215 where i am, it's almost as good as the 274qpf-qd, but not quite.
Thanks, but I think I am going to go with either the AOC monitor or one of the $200 ones recommended above. I don't recognize the brand and can't find reviews for it.
