Fans
Go to solution Solved by filpo,
10 minutes ago, daxooly said:
Budget (including currency):
Country: UK
Games, programs or workloads that it will be used for:
https://uk.pcpartpicker.com/list/YXvT34
idk how to connect all the fans and if i need a fan controller or not and if so witch one?
also i dont have anything to daisychain together the fans other than whats already done in the case.
you seem to have 8 fans in that build (not including the CPU fan) so you'll have to get two sets of three 4 pin to one 4 pin splitters to run all of your fans
What's your current build that you're upgrading to and what's your budget and use case?
or what's the rest of your planned build?
B550 GAMING GEN3 (msi.com)
EDIT: i see from your other thread that it was an £800 build. I'm happy to say that the market has gotten better here in the UK and you can get an am5 build if you already have a 2060 super
PCPartPicker Part List
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (£42.54 @ Amazon UK)
Motherboard: *MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  (£159.00 @ Computer Orbit)
Memory: *TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£105.80 @ Amazon UK)
Storage: KIOXIA EXCERIA PLUS G3 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£106.99 @ Scan.co.uk)
Case: *Montech SKY TWO ATX Mid Tower Case  (£79.99 @ Scan.co.uk)
Power Supply: Cooler Master MWE Gold 850 - V2 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£99.99 @ AWD-IT)
Custom: 7500F (£122.00)
Total: £716.31
Generated by PCPartPicker 2024-02-27 17:37 GMT+0000
Country: UK
Country: UK
Total: £716.31
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
For these situations I think SATA powered fan hubs are simpler and cleaner than fan splitters.
Arctic make a 10 fan hub which you can find on Amazon for £8 in the UK.
https://www.amazon.co.uk/ARCTIC-Pro-Gen-Ultrawide-Adjustment/dp/B087FY5CNT
I might be experienced, but I'm human and I do make mistakes. Expand for common PC building advice, a short bio and a list of my components and other tech. I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need.
Common build advice: 1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticably improve performance past 240mm.
useful websiteshttps://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
He/Him
I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 3 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). While I believe I have an decent amount of experience in spec’ing, building and troubleshooting computers, keep in mind I'm not an expert or a professional and I make mistakes.
Favourite Games of all time: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii
Main PC: https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C
Secondary PC: https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P
TrueNAS Server: https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C
Laptop: 13.4" ASUS GZ301ZE ROG Flow Z13, WUXGA 120Hz, i9 12900H, 16GB DDR5, 1TB NVMe SSD, 4GB RTX 3050 Ti, TB4, Win11 Home, Used with: 2*ThinkPad Universal Thunderbolt 4 Dock, Logitech G603, Logitech G502 Hero, Logitech K120, Logitech G915 TKL, Xbox Elite Wireless Controller Series 2, Logitech G PRO X Gaming-Headset (with Blue Icepop in Black), {specs to be updated: two monitors}
Other: LTT Screwdriver, LTT Stubby Screwdriver, IFIXIT Pro Tech Toolkit, Playstation 1 SCPH-102, Playstation 2 SCPH-30003, Gameboy Micro Silver OXY-001, Nintendo Wii U WUP-001(03), Playstation 4 CUH-1116A, Nintendo Switch OLED HEG-001, Yamaha RX-A4A Black AV Receiver, Monitor Audio Radius (4*90s, 1*200s, 2*270s, 1*380s), TP-Link TL-SG105-M2, Netgear GS308, IPhone 14 Pro Max 128GB Space Black, Secretlab TITAN Evo (Black SoftWeave Plus Fabric), 2*CyberPower BR1200ELCD-UK BRICs Series, Samsung 40" ES6800 Series 6 SMART 3D FHD LED TV, UGREEN USB 3.2 Gen 2 10Gbps M.2 NVMe SSD Enclosure, SABRENT 3.5" SATA drive docking station
Country: UK
I don't understand why you are buying so many fans and static LED ones to boot.
The case comes with 3 A-RGB fans and will require one 5v A-RGB header and one 4-pin PWM fan header. Sadly the motherboard does not have a 5v A-RGB header.
The additional Corsair fans strike me as excessive.
