LC Power 1000M V2.31
Darkharry
Go to solution Solved by --SID--,
It's not super silent in real world and it lacks OTP. Besides that the quality is low. Don't use it if you really need 1000w. Otherwise get a lower wattage PSU of better quality.
Its super silent modular series and i can get it for 50e and its gold rated, on PSU tier list its either speculative position or tier B mid range and i dont think the build really matters since its a 1000W i just wanna know if its good and worth it
50 euros? new? or used?
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
New
What is OTP?
22 minutes ago, Darkharry said:
New
Not a bad deal but if you don’t need it go for as @--SID-- said
then again, you probably can’t get a better quality psu at that price. Do you have a link for the product?
Current parts list
6 minutes ago, Darkharry said:
What is OTP?
Over Temperature Protection. Not a bad idea when a very basic sleeve bearing fan is in the PSU.
https://www.lc-power.com/en/product/pc-power-supply-units/super-silent-modular-series/lc1000m-v231.html
From what i have seen this is the one
24 minutes ago, Darkharry said:
I mean to the listing
Current parts list
Is it good value for 50e tho? I could re sell it at higher price if i do take it like 110e somewhere in that range
yes
Current parts list
