Budget (including currency): Enough for either CPU
Country: US
Games, programs or workloads that it will be used for: 1440P gaming
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): 3070TI. 1440P 170hz monitors
Trying to decide if it's worth getting a 5700X3D or a 5800X. From what I've seen online, the 5800X performs better(?) yet costs less. Is this the case or am I misunderstanding something?
https://linustechtips.com/topic/1560132-difference-between-5700x3d-and-5800x/
Country: US
The 5800X3D performs better than the 5700X3D in games. Don't confuse a 5800X3D and a 5800X, they are not the same.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Correct, I was recommended either the 5700X3D and 5800X for a build upgrade so I was trying to figure out which would be the right move!
The 5800X is a non-3D chip, the 5700X3D has 3D Vcache on the processor which really helps boost performance in games. The 5800X does have a higher clock speed so in some scenarios, most likely multithreaded like Cinebench or rendering, the 5800X will come ahead, although just slightly. For gaming, the X3D chip is far superior and will last you for a while longer than the 5800X.
Which CPU do you have now?
If you're not going to upgrade the 3070Ti till you upgrade the whole platform/PC, then get a 5700X and call it a day. It's enough for a 3070Ti on 1440p.
If you're highly competitive or if you plan on upgrading the GPU without changing the platform, then get an X3D, either the 5700X3D or 5800X3D.
The non-x3d chips are a bit better for work (rendering, compression/decompression, encoding/transcoding, video editing, ...), but they are much worse for many games.
If you're on a 3700X or 3800X, the upgrade to a 5700X makes no sense on 1440p.
