USB Headers on Motherboard
Go to solution Solved by johnno124,
1 hour ago, leclod said:
You've got one "1 x Front Panel Type C USB 3.2 Gen2x2 Header" , so yes
Otherwise it would be impossible, imagine all the guys with x1 header and x2 case plus all the guys with x2 header and x1 case.
So many problems...1x and 2x must be inter compatible like USB3 type A...otherwise it would be clearly stated (I searched the manual and couldn't find any statement)
Ok thanks, Was a bit confused because PCPP was say a header adapter may be required but nothing concrete.
Hi peoples of the internets.
I know i asked this already but i got 0 responses so i fear it fell down the internet void
Struggling to find a clear answer on google (keeps giving me articles for adapters). The Motherboard i am looking to get (ASRock Z790 Riptide) has a USB 3.2 Gen 1 Header and a USB 3.2 Gen 2x2 header. The case (Montech King 95 Pro) has 2 USB 3.2 Gen 1 Type A and a USB 3.2 Gen 2 Type c connector. From what i can find, the 2 Gen 1 type As will run of a single header on the motherboard. My main concern is, will i be able to plug the Gen 2 type c into the Gen 2x2 header on the motherboard (Running at Gen 2 speeds of course) Or will i need an adapter to convert the gen 2x2 into a gen 2 header.
Thank
 Main Desktop
CPU: AMD Ryzen 5 2600X @ 3.6GHz, Stock Cooler
MOBO: ASUS ROG STRIX B350 F Gaming motherboard
RAM: 32GB(4x8GB) Team T-FORCE Night Hawk RGB 3000MHz DDR4
GPU: ASUS ROG STRIX GTX 1060 6GB
STORAGE: 1TB Western Digital Blue HDD, 2TB Seagate Barracuda, 250GB Samsung 850 Evo, 1TB Samsung 970 Evo Plus, 240GB WD Green M.2 SATA SSD
CASE: Cougar Turret RGB
PSU: CoolerMaster GX550W CM Storm
OS: Windows 10 Home
Monitor: Samsung Oddessy G6 27" 1440p, Viewsonic VX2455 144Hz
Mouse: Logitech G502 Lightspeed Wireless Mouse
Keyboard: ASUS Flare II Animate
Headphones: HyperX Cloud Alpha S Black
Microphone: HyperX Quadcast S
WIFI: ASUS PCE-AC55BT
https://au.pcpartpicker.com/user/johnno12/saved/gKgD23
1
Laptop:
Dell Inspiron 15-5000
CPU: i5-8250U Quadcore with hypertheading
GPU: AMD Radeon 540 4GB Hybrid Graphics
Storage: Micron 1100 SATA 256GB SSD
OS: Windows 10 Home
1
Edited by leclod
I'm willing to swim against the current.
 Main Desktop
OS: Windows 10 Home
1
Laptop:
OS: Windows 10 Home
1
