I Need some help you guys.....
Sir Judgementz
I am in IL, we have 115 power lines here. i want to make sure its safe to fun my stuff this way.
i have a Lg27gn950-b monitor ( https://www.lg.com/us/monitors/lg-27gn950-b-gaming-monitor) , a tv antenna ( https://www.microcenter.com/product/661649/inland-an-3029-v3-digital-tv-antenna) , a lg un7000 4k tv (https://www.bestbuy.com/site/lg-43-class-un7000-series-led-4k-uhd-smart-webos-tv/6417302.p?skuId=6417302) , a k100 keyboard (https://www.microcenter.com/product/628179/corsair-k100-rgb-optical-mechanical-gaming-keyboard-corsair-opx-switch), a corsair mmo mouse (https://www.microcenter.com/product/618138/corsair-scimitar-rgb-elite-gaming-mouse) , a amd 7800x3d (https://www.microcenter.com/product/674503/amd-ryzen-7-7800x3d-raphael-am5-42ghz-8-core-boxed-processor-heatsink-not-included) , a asrock x670e (https://www.microcenter.com/product/652773/X670E_Pro_RS_AMD_AM5_ATX_Motherboard) , corsair ram (https://www.microcenter.com/product/653876/Dominator_Platinum_RGB_32GB_(2_x_16GB)_DDR5-6000_PC5-48000_CL36_Dual_Channel_Desktop_Memory_Kit_CMT32GX5M2D6000Z36_-_Black), a lancool 3 case (https://www.microcenter.com/product/649250/LANCOOL_III_RGB_Tempered_Glass_ATX_Mid-Tower_Computer_Case_-_Black), a h150i (https://www.microcenter.com/product/627103/iCUE_H150i_ELITE_CAPELLIX_360mm_RGB_Water_Cooling_Kit), corsair aio lcd kit (https://www.microcenter.com/product/661715/corsair-icue-elite-cpu-cooler-lcd-display-upgrade-kit-black), soundbar (https://usa.yamaha.com/products/audio_visual/sound_bar/yas-108/index.html), subwoofer (https://www.ebay.com/itm/315055714813?chn=ps&mkevt=1&mkcid=28), a 20in fan (https://www.homedepot.com/p/Commercial-Electric-20-in-3-Speed-High-Velocity-Floor-Fan-SFC1-500B/318152095), and a surge protector (https://www.microcenter.com/product/600933/SurgeArrest_P12U2_12-Outlet_Surge_Protector_w-_2_USB_-_Black), and a google home nest "(https://www.amazon.com/Google-Display-Generation-Renewed-GA00516X-GA00515X/dp/B0CLQ5BVDJ), with a evga 850 psu (https://www.amazon.com/EVGA-Supernova-Modular-Warranty-220-G2-0850-XR/dp/B00IKDETOC).
They are all pluged in that protector. The tv is off when the pc is on, the fan runs most the day when i am in there on the pc or tv, the soundbar is for both tv and pc. the google always on. soundbar is off after 10pm. will this be safe to use. Everything been fine running for about a year but i just added the cpu and the 20in fan.
8 minutes ago, Sir Judgementz said:
so take the fan off then?
😀 I meant the text is cramped, overwhelming
I'm willing to swim against the current.
Sorry hope this helps a bit, any thianks for any help you can give.
i have a Lg27gn950-b monitor ( https://www.lg.com/us/monitors/lg-27gn950-b-gaming-monitor),
a tv antenna ( https://www.microcenter.com/product/661649/inland-an-3029-v3-digital-tv-antenna),
Usage Information:
  • All devices are plugged into the surge protector.
  • The TV is turned off when the PC is on.
  • The fan runs most of the day when using the PC or TV.
  • The soundbar serves both the TV and PC.
  • The Google Home Nest is always on.
  • The soundbar is turned off after 10 pm.
Note: Everything has been running fine for about a year, but recently, a CPU and a 20in fan were added.
Edit: Removed numbers
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15 with one fan
FS in Denmark/EU:
Asus Dual GTX 1060 3GB. Used maximum 4 months total. Looks like new. Card never opened. Give me a price.
Yes PSU's is 100-220v, 110-240v
FS in Denmark/EU:
what about the watts its draws with the pc, fan, soundbar is all running at the same time?
Oh this wont work:
Surge Protector: APC SurgeArrest P12U2 12-Outlet Surge Protector with 2 USB Ports
It uses 120V input
Just drop the surge protector. PSU is fine for that PC even if you got a 4090
FS in Denmark/EU:
im sorry i think i explained it wrong. i was trying to find out if all them item on the surge protector was safe to run, in the matter i listed. the pc is built and working great on there. i just dont want to overdraw the power (watts or amps)
Yes. As long as you're not plugging an air conditioner into the same circuit as all the stuff on your list, it should be fine. (And even then, you just run the risk of tripping the breaker when it kicks in.)
Your surge protector is rated for 15 amps, and there's a good chance you're plugged into a 15 amp circuit. If you plug everything into the wall instead of the surge protector, and it's drawing too much power, you'll just trip the breaker feeding the circuit your stuff is plugged into. (Besides, it's good practice to have your electronics plugged into a surge protector.)
15 amps at 120 volts is 1,800 watts. (Ohm's Law says Watts = Volts x Amps.) North American electric code says a sustained draw should only be 80% of a circuit's rated capacity, so that leaves you 1,500 watts for all your devices. (That's also why electric space heaters in the US all say they're up to 1500 watts regardless of size, fun fact.)
Your PC is not drawing 850 watts all the time, just because you have an 850 watt power supply. That's just its maximum capacity. You would need to plug it into a metered outlet or a tool like a Kill-a-Watt to find out exactly what it's drawing at any given moment, but I bet it's drawing less than that even with a heavy gaming load.
A fan only draws about 50 watts on high.
thank you so much and the fan only draws that much even beiing a 20in high velocity fan, new to me 🙂
