I’m making two builds for a couple of friends. I need recommendations and if the wattages are correct.
I have two separate builds that I’m planning to build for a couple of friends of mine.
Build 1: AMD Ryzen 7 5800x3d, a Deepcool Assassin 3 Air cooler, two crucial p3 plus nvme. 1tb and a 4tb, a MSI Mag B550 Tomahawk Max Wifi, a Gigabyte RTX 4060 Eagle OC, 32Gb of Corsair Vengeance RGB Pro RAM “3200mhz”. Corsair ICUE AR120 fans a three pack. Lian Li Dynamic EVO 11, Corsair CX650m psu.
Build 2: AMD Ryzen 5 5600, EVGA GTX 1660 SC Ultra Gaming, Crucial P3 500gb, and a 1tb Silicon Power NAND 3d A55. And a Corsair 4000d airflow. A Corsair CX650m PSU. A Gigabyte B550 Aorus elite V2 WiFi. 32gb of Corsair Vengeance Pro RAM “3200mhz”
what are some recommendations? To change and are the wattages enough or too much?
Both of them plan to use them for streaming/gaming
1 minute ago, brob said:
You may want a separate thread for each build.
This.  And let us know country, budget and use case as well.  Off hand, I’m gonna say the split drives are unnecessary these days, just partition one large SSD.  The 4060 and 1660 are kind of weak compared to how much it seems your spending on these PCs if these are for gaming.  Those fans and that RAM are also kind of a waste of money when you’re only getting those GPUs.
I edit the shit out of my posts.  Refresh before you respond.
not kind of weak
laughably and pathetically weak for these builds
a 4070 should be in place of that crappy 4060 (or atleast a used 3080) and a used ~200$ 6700xt in place of that ancient ~100$ 1660s that belongs in a 500$ budget build
just specify country alongside each builds budget and usecases cause these 2 builds are clearly quite different budget wise
Build 1: his budget is $2,500.
Build 2:his is $800
Their use cases are specifically for streaming/gaming.
We’re all based in the US
Here’s the Thread for Build one:
Build two: AMD Ryzen 5 5600, EVGA GTX 1660 SC Ultra Gaming, Crucial P3 500gb, and a 1tb Silicon Power NAND 3d A55. And a Corsair 4000d airflow. A Corsair CX650m PSU. A Gigabyte B550 Aorus elite V2 WiFi. 32gb of Corsair Vengeance Pro RAM “3200mhz”
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($349.00 @ Newegg)
CPU Cooler: ARCTIC Liquid Freezer III A-RGB 48.82 CFM Liquid CPU Cooler  ($107.79 @ Amazon)
Motherboard: *MSI X670E GAMING PLUS WIFI ATX AM5 Motherboard  ($249.99 @ Amazon)
Memory: Silicon Power Value Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($94.97 @ Amazon)
Storage: *Acer Predator GM7000 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($124.99 @ Amazon)
Video Card: PNY VERTO OC GeForce RTX 4080 SUPER 16 GB Video Card  ($1209.32 @ Amazon)
Case: Montech SKY TWO ATX Mid Tower Case  ($79.98 @ Amazon)
Power Supply: *Thermaltake Toughpower GF A3 - TT Premium Edition 1050 W 80+ Gold Certified Fully Modular ATX Power Supply  ($127.08 @ Amazon)
Total: $2343.12
Generated by PCPartPicker 2024-02-27 10:46 EST-0500
5 minutes ago, MorsAngelus146 said:
Build 2:his is $800
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor  ($170.00 @ Amazon)
CPU Cooler: *Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($33.90 @ Amazon)
Motherboard: *Gigabyte B550M DS3H AC Micro ATX AM4 Motherboard  ($89.99 @ Amazon)
Memory: *Silicon Power GAMING 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($55.97 @ Amazon)
Storage: *Leven JPS600 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($58.99 @ Amazon)
Case: *Phanteks Eclipse G360A ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: Thermaltake Smart BM3 850 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($79.98 @ Amazon)
Custom: Used 3060 Ti ($260.00)
Total: $798.82
Generated by PCPartPicker 2024-02-27 10:49 EST-0500
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
