Need help with new mobo!
I’ve been dealing with this ASUS motherboard for 2 weeks now trying to troubleshoot reason to why the XMP profile crashes Fortnite on DIMM slots 2 and 4. When I switch the DIMM to slots 1 and 3, XMP takes quite a while to Boot and post. I’ve tried contacting ASUS themselves I haven’t heard anything back yet. I bought the recommended RAM and all the parts are compatible. Please help you’re my only hope.
specs~
i9-13900k
Asus motherboard z790 A Wifi
G.Skill Trident Z5 RGB series (Intel XMP 3.0) DDR5 RAM
RTX 4070ti
1TB
Okay, so when you have XMP turned off everything works fine, but when XMP is turned on you experiance crashing in Fortnite?
What are the crashs like? is it just fortnite freezes and then closes? or are you seeing a blue screen of death?
Is it only fortnite that crashes?
I might be experienced, but I'm human and I do make mistakes. Expand for common PC building advice, a short bio and a list of my components and other tech. I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need.
Common build advice: 1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticably improve performance past 240mm.
useful websiteshttps://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
He/Him
I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 3 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). While I believe I have an decent amount of experience in spec’ing, building and troubleshooting computers, keep in mind I'm not an expert or a professional and I make mistakes.
Favourite Games of all time: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii
Main PC: https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C
Secondary PC: https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P
TrueNAS Server: https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C
Laptop: 13.4" ASUS GZ301ZE ROG Flow Z13, WUXGA 120Hz, i9 12900H, 16GB DDR5, 1TB NVMe SSD, 4GB RTX 3050 Ti, TB4, Win11 Home, Used with: 2*ThinkPad Universal Thunderbolt 4 Dock, Logitech G603, Logitech G502 Hero, Logitech K120, Logitech G915 TKL, Xbox Elite Wireless Controller Series 2, Logitech G PRO X Gaming-Headset (with Blue Icepop in Black), {specs to be updated: two monitors}
Other: LTT Screwdriver, LTT Stubby Screwdriver, IFIXIT Pro Tech Toolkit, Playstation 1 SCPH-102, Playstation 2 SCPH-30003, Gameboy Micro Silver OXY-001, Nintendo Wii U WUP-001(03), Playstation 4 CUH-1116A, Nintendo Switch OLED HEG-001, Yamaha RX-A4A Black AV Receiver, Monitor Audio Radius (4*90s, 1*200s, 2*270s, 1*380s), TP-Link TL-SG105-M2, Netgear GS308, IPhone 14 Pro Max 128GB Space Black, Secretlab TITAN Evo (Black SoftWeave Plus Fabric), 2*CyberPower BR1200ELCD-UK BRICs Series, Samsung 40" ES6800 Series 6 SMART 3D FHD LED TV, UGREEN USB 3.2 Gen 2 10Gbps M.2 NVMe SSD Enclosure, SABRENT 3.5" SATA drive docking station
Whats the exact spec of this memory kit? It could just be that the memory kit is too fast for your CPU.
No sadly when XMP is turned off there’s still random crashes. sometimes BSOD or things just won’t stay open.
It’s DDR5-6400 1.40v
I suggest testing your RAM. Download memtest (see software megathread) onto a usb stick and boot and run it.
He/Him
I just bought the ram, it came in yesterday.
RAM can and does sometimes arrive broken.
He/Him
Although, now I look at what you've said in total: what makes you think this is a motherboard or XMP issue? you seem to be saying that your having random crashes with XMP on or off?
He/Him
Just bought the mobo, hard drive, ram. Fortnite won’t run when I launch XMP with the ram in slot 2 and 4. But when I switch the slots to 1and 3. when I force boot the pc into , I force launch windows and then I can play Fortnite on dx12 @ over 200 frames.
So it runs fine in slots 1 and 3 (apart from boot times) but not 2 and 4?
He/Him
I mean I have to force shut down everything twice for a clean start up but yes. Boot times are a lot longer with slots 1 and 3, unlike 2 and 4. But actually can run programs with a longer boot time? This is why I need help
Okay, sounds like a dead ram slot. Try a single stick in slot 2. After that try a single stick in slot 4. That should identify if it is a dead slot and which slot is dead.
He/Him
Slot 2 and 4 work and booted to Windows fine on their own but cannot run Fortnite at all still on their own. No hiccups or anything seeming out of the norm
So both cases (a single stick in slot 2 and a single stick in slot 4) lead to crashes. Okay, very strange.
Do you use the same stick of ram for both tests?
He/Him
No I swapped out the sticks but this happened to the last ram I had as well thinking it was a ram issue.
Showing the crashing to swapping sticks to slot 1 and 3 to show hard boot and no crashing on Fortnite
Okay, I think the next step is to send the motherboard back to ASUS for repairs.
He/Him
Anything?
1 hour ago, Class said:
Anything?
You have something dead reading through all of that. I'd be most concerned about a dead RAM kit, but as @will0hlep suggested, a dead motherboard is still a possibility.
I ruled out RAM issue cause OP said the system worked with the RAM in slots 1 and 3.
He/Him
And I'm ruling it in because when it's in slots 1 and 3 it's running at a snail's speed of DDR5 4000 compared to the 4800 JEDEC it would be running at in slots 2 and 4.
Yep fair point, I'd skipped over that. I'll also admit that for my theory to make sense, multiple slots need to be damaged (but I believe OP suggested he was having issues with only one stick installed regardless of which stick was used, so both ram sticks dead or 2 dead slots???).
Could it be that the CPU needs a reseat?
He/Him
@Class
Is this a new machine you've built 2 weeks ago, or is this an older machine that has developed a fault?
He/Him
