Nvidia Control Panel only showing 3D options? How to fix
gt710
so i have a laptop using RTX 3050 but when i go to the nvidia control panel all i get is 3d options聽
did some google but could not find a fix
i did read that i may need to disable the intel IGPU but im able to do so in the bios and when i disable it in device manger it just switches to using a basic driver
what can i do i really want to use RTX VSR with this laptop to test it out
Did you try reinstalling your GPU drivers? Might be a good idea to uninstall using DDU and reinstalling from the Nvidia site
>> Please consider tagging me (with a @) or quoting my reply so I can more easily get back at you! <<
Always happy to help!! 馃
thanks i tried this now and still showing 3D options only
