I NEED HELP WITH MY FIRST PC
geoffery
i recently bought a new pc and it is starting but not posting on the screen.
spec:i5 12400f, gtx 1650 with 16gb ddr4 ram.
PC: i5 12400f, 16gb ram, 512gb ssd, GTX 1650
Okay, did you plug the monitor into the graphics card?
I might be experienced, but I'm human and I do make mistakes. Expand for common PC building advice, a short bio and a list of my components and other tech. I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need.
Common build advice: 1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticably improve performance past 240mm.
useful websiteshttps://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
He/Him
I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 3 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). While I believe I have an decent amount of experience in spec’ing, building and troubleshooting computers, keep in mind I'm not an expert or a professional and I make mistakes.
Favourite Games of all time: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii
Main PC: https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C
Secondary PC: https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P
TrueNAS Server: https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C
Laptop: 13.4" ASUS GZ301ZE ROG Flow Z13, WUXGA 120Hz, i9 12900H, 16GB DDR5, 1TB NVMe SSD, 4GB RTX 3050 Ti, TB4, Win11 Home, Used with: 2*ThinkPad Universal Thunderbolt 4 Dock, Logitech G603, Logitech G502 Hero, Logitech K120, Logitech G915 TKL, Xbox Elite Wireless Controller Series 2, Logitech G PRO X Gaming-Headset (with Blue Icepop in Black), {specs to be updated: two monitors}
Other: LTT Screwdriver, LTT Stubby Screwdriver, IFIXIT Pro Tech Toolkit, Playstation 1 SCPH-102, Playstation 2 SCPH-30003, Gameboy Micro Silver OXY-001, Nintendo Wii U WUP-001(03), Playstation 4 CUH-1116A, Nintendo Switch OLED HEG-001, Yamaha RX-A4A Black AV Receiver, Monitor Audio Radius (4*90s, 1*200s, 2*270s, 1*380s), TP-Link TL-SG105-M2, Netgear GS308, IPhone 14 Pro Max 128GB Space Black, Secretlab TITAN Evo (Black SoftWeave Plus Fabric), 2*CyberPower BR1200ELCD-UK BRICs Series, Samsung 40" ES6800 Series 6 SMART 3D FHD LED TV, UGREEN USB 3.2 Gen 2 10Gbps M.2 NVMe SSD Enclosure, SABRENT 3.5" SATA drive docking station
yes
im not that stupid
1 minute ago, geoffery said:
yes
im not that stupid
power supply switch to on?
front panel headers all in correctly? (check manual)
All power connectors seated correctly
if none of that works try a cpu and gpu reseat and while you're at it check the contacts on the 12400f and the socket pins (cpu reseat in socket and gpu in pcie slot)
what're the rest of your specs?
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
8 minutes ago, geoffery said:
yes
im not that stupid
We have to ask 🙂
He/Him
yes psu switch is on
thanks is will try all of this
Try giving Ram a reseat too
He/Him
any debug lights? (if any)
Current parts list
it worked
thanks
13 minutes ago, geoffery said:
it worked
thanks
happy to help 👍
Current parts list
i got into the bios and the ssd is showing but not registering
it is an ssd that used to be in another system
Is the ssd is going to be used as your C: drive or storage? Because either way it could be a bad cable if it is a sata ssd. Or you have to reformat the drive.
it is a drive
thanks for the info
You might have to reformat it. Or have to do a clean windows install
Current parts list
I am trying to install windows and i have 2 options to install
with one of them the pc cant see the drive with windows and on the other it says my system specs are not enough even though they are.
