On the fence between rtx 4090 and rtx a 6000
Ashish7334
Hi Guys,
Can someone say which GPU to go for 3ds max and why. I have written to NVIDIA they are inclined towards rtx a6000. Im not liking because its an old product and specfications are outdated. In my experience more vram keeps a rig from becoming obsolete much more that a fast gpu.
No too techie i am./ Someone tell me what to to.
AMD Ryzen R9 5900X  | Arctic Liquid Freezer II 360  |  GIGABYTE X570S AERO G  |  2x32GB G'skill TridentZ 4000MHz  | MSI RX 6900 XT Gaming Z Trio 16GB Dark Base Pro 900 (Orange)  | TOSHIBA 4TB 3.5" Drive - Game Drive | Crucial MX200 250GB 2.5" SSD - Boot Drive | Cooler Master V750 PSU |
Living Room PC: AMD Ryzen 2400G | MSI RX VEGA 56 8GB AERO | 2x8 GB Crucial Ballistix 2400MHz | Intenso 250GB SSD | Seagate 500 GB HDD | Node 202 + 850W PSU |
1 minute ago, Edgar R. Zakarian said:
Also people discussing
I'm not sure what 3DS counts as but I think it's closer to real time rendering like unreal engine, no ?
Well NVIDIA will prefer to sell you the more expensive card.
RTX 4090 is usually faster... As long as your projects don't need more VRAM than the card has... In which case the RTX 6000 will be a better choice.
At a crude level, if you need more VRAM, the choice is made.
The pro cards also come with ECC so may be more stable/reliable. Not that I'm saying a 4090 would be unstable. Stuff like this is hard to quantify. If you're making a living off this, it is a factor to consider. Random ram errors might be rare, but as ram quantity increases, the chances of a random event causing an error does too.
Main system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, Corsair Vengeance Pro 3200 3x 16GB 2R, RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
