Rx7600 ramps to max speed while being at 50°c
SadD0G
I have no idea why, but I've noticed after I installed windows and drivers that my gigabyte rx7600 starts ramping up to max speed whilist being at around 47 degrees... Sometimes it stops but keeps going right after. Rest of the PC fans are fine. Is this normal?
What is the hotspot temp? Because fans adjust based on hotspot temp (at least on my RX 6800 XT).
Also you can limit the max fan speed or set your own fan curve in the Adrenaline SW.
I know my card will not go over 90C hotspot at 100% load so I capped my fans at max 75% for example. You can tune it as you want.
