2 RAM Sticks @7200MHz or 4 Sticks @4000Mhz
I bought 4 sticks of DDR5 T-Force Delta sticks, only to find out that I can't use them all at 7200 (pc won't post). Which is going to be better for gaming? Mainly Escape from Tarkov which is a very RAM depend game. Should I use the 2 sticks and enable XMP for 7200MHz or use all 4 sticks at 4000Mhz.
What CPU are you using?
Higher speed is going to be more important in almost all scenarios, though depending on the CPU platform you might be better off with lower speeds.
Here are my specs:
CPU: i9-14900K
GPU: RTX 3070
Motherboard: MSI MAG Z790
This CPU is a monster with 32 cores. So i don't know exactly what would be best for it speed wise.
4 minutes ago, Limitt said:
Here are my specs:
CPU: i9-14900K
GPU: RTX 3070
With a 14900K, you want as high a memory speed as possible. Go for the 7200 setup.
What if I get 2 sticks of 32GB that can run at 7200MHz. Would this be something that would still post? (If there are sticks of 32GB that can run at 7200MHz).
Thank you so much for your help.
There aren't, the highest rating you can get 2x32GB is 6800MT/s, and even then, speeds above 6000MT/s with 2x32GB ends up somewhat hit or miss depending on how good your CPU is (though 6400 should usually work, especially if you have a chip where 7200 works on 4 DIMM boards).
If you really want more capacity at 7200, look into getting the 2x24GB setups, those are available at 7200 CL34.
I thought the current data showed that performance (in gaming) plateued after 6000Mhz on the 13th gen. Has that really changed for the 14th gen? Cause if not, the OP should just buy 6000 Mhz ram (which will be stable) in the capacity they need.
I might be experienced, but I'm human and I do make mistakes. Expand for common PC building advice, a short bio and a list of my components and other tech. I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need.
Common build advice: 1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticably improve performance past 240mm.
useful websiteshttps://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
He/Him
I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 3 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). While I believe I have an decent amount of experience in spec’ing, building and troubleshooting computers, keep in mind I'm not an expert or a professional and I make mistakes.
Favourite Games of all time: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii
Main PC: https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C
Secondary PC: https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P
TrueNAS Server: https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C
Laptop: 13.4" ASUS GZ301ZE ROG Flow Z13, WUXGA 120Hz, i9 12900H, 16GB DDR5, 1TB NVMe SSD, 4GB RTX 3050 Ti, TB4, Win11 Home, Used with: 2*ThinkPad Universal Thunderbolt 4 Dock, Logitech G603, Logitech G502 Hero, Logitech K120, Logitech G915 TKL, Xbox Elite Wireless Controller Series 2, Logitech G PRO X Gaming-Headset (with Blue Icepop in Black), {specs to be updated: two monitors}
Other: LTT Screwdriver, LTT Stubby Screwdriver, IFIXIT Pro Tech Toolkit, Playstation 1 SCPH-102, Playstation 2 SCPH-30003, Gameboy Micro Silver OXY-001, Nintendo Wii U WUP-001(03), Playstation 4 CUH-1116A, Nintendo Switch OLED HEG-001, Yamaha RX-A4A Black AV Receiver, Monitor Audio Radius (4*90s, 1*200s, 2*270s, 1*380s), TP-Link TL-SG105-M2, Netgear GS308, IPhone 14 Pro Max 128GB Space Black, Secretlab TITAN Evo (Black SoftWeave Plus Fabric), 2*CyberPower BR1200ELCD-UK BRICs Series, Samsung 40" ES6800 Series 6 SMART 3D FHD LED TV, UGREEN USB 3.2 Gen 2 10Gbps M.2 NVMe SSD Enclosure, SABRENT 3.5" SATA drive docking station
Why do you need so much ram? If all your doing is gaming (and office work and browsing) 32GB will be completely fine.
He/Him
Also 8000+ but intel imc is inconsistent
Isnt 7200 xmp still somewhat hit or miss on intel? I mean you are paying for the xmp getting a 7200 kit instead of whatever lower bin 6400c32 or whatever kit that comes with 24gbit m die and manually tuning that to 7600-8800 (depending on cpu imc) so youd want the xmp you paid for to actually just work out of the box wirh just 1 click and no manual tuning
At least going of HW Unboxed's testing, there is some scaling past 6000MT/s. It definitely is starting to hit diminishing returns, but then again, the price difference between 6000 CL30 and 7200 CL34 is pretty small (~$20 for 2x16GB, ~$30 for 2x24GB), so if you have a chip that is capable of running 7200MT/s, you might as well run the higher clock speed.
It is, though since a) their 7200 XMP already does work, b) 2x24GB DIMMs are more likely to work at high speeds out of the box (assuming you have a BIOS revision with decent support for them at least), c) 24Gb M die isn't as consistent as 16Gb A die where higher rated DIMMs actually mean a bit more, and d) the price difference is only about $30 US. Besides, 14th gen on average should be better at high speeds on average, so 7200 should be a fair bit more hit than miss than it was on 13th gen, though there definitely are chips that will fail to do 7200+.
What is your return window on the CPU?   I would have gone 13600K, saving money to put to a much better GPU.
Possible?
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Possible?
It was parts from my old build (RTX 3070). And i don't think im going to upgrade for a bit.
Because Escape from Tarkov has spaghetti code and you need to have a lot of ram to run smooth frames. Just a poorly optimized game lol
