My siblings build/ the final build... again
Go to solution Solved by filpo,
Just now, Hellowpplz said:
Budget (including currency): 1000$
Country: U.S.A
Games, programs or workloads that it will be used for: Gaming on high settings at 1440p 60fps or 1080p 90 fps
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): EVERY GAME. This pc is for my sibling and he has lots of variety from cyberpunk 2077 to forza horizon 5
In my last build you will see I got 2 27" monitors and I decided to have each one on a separate desk. I had a 7000$ budget and ended up with 1000$ left over that I REALLY dont need for anything.
I already posted this but for some reason people didn't understand I was building a pc for a sibling/ because I wanted to and started roasting me. I just want build tips please. :old-sad:
https://pcpartpicker.com/list/yPDJ28
try this
PCPartPicker Part List
CPU Cooler: *Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($33.90 @ Amazon)
Motherboard: *ASRock B650M-HDV/M.2 Micro ATX AM5 Motherboard  ($120.98 @ Newegg)
Memory: *Silicon Power Value Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($92.97 @ Amazon)
Storage: *Western Digital Green SN350 1 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($54.99 @ Amazon)
Video Card: *PowerColor Fighter OC Radeon RX 7800 XT 16 GB Video Card  ($489.99 @ Newegg)
Case: *Phanteks Eclipse G300A (1 Fan) ATX Mid Tower Case  ($49.99 @ Amazon)
Power Supply: *Thermaltake Smart BM3 650 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($59.99 @ Amazon)
Custom: 7500F ($155.00)
Total: $1057.81
Generated by PCPartPicker 2024-02-22 08:50 EST-0500
Country: U.S.A
I edit my messages more than not –
Probably some dude on the internet
https://linustechtips.com/topic/1559342-my-siblings-build-the-final-build-again/
Country: U.S.A
try this
Total: $1057.81
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
8 minutes ago, filpo said:
try this
Total: $1057.81
Why the 7500F price?
Where did you find that?
aliexpress
nearly $60 cheaper than a 7600 for the same performance. You lose the iGPU tho
Total: £1040.95
11 minutes ago, filpo said:
aliexpress
Also i just noticed that case has 1 fan, do i need to buy more separately?
Country: U.S.A
Are you in the USA?  We don't put dollar signs after numbers...
Is the 5800X3D a hand-me-down CPU, as the price is odd.  Otherwise it's a fine machine, will work well.
Yes, add 2x 120mm fans to the front.
I would have roasted you for this line, not the PC...
"I had a 7000$ budget and ended up with 1000$ left over that I REALLY don't need for anything."
Saying you don't need $1000 for anything is ridiculous.  We don't need to  know your finances, or that you blow $6k on your setup and have $1k to throw away cuz you are so rich you don't need it 🙂
Otherwise, I'm just concerned about the machine and it's a decent build.
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 1000 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
OnePlus Ecosystem:
Other Tech:
You shouldn't need to. If you want to then get the p12 5 pack but there's no need
Total: £1040.95
Country: U.S.A
Good list, I have the same GPU and psu myself and it works wonderfully, I would consider getting more ram and getting a mother board with newer bios already installed bc it's annoying to update bios. Other wise it's a pretty good build. (Check if the GPU fits bc it is extremely massive and it would be a good idea to add two 120 fans in the front)
GPU will fit, it's the same size as a 1070 and I had one in that box with 2 front fans added.
It's a surprisingly spacious interior.
OnePlus Ecosystem:
Other Tech:
Fr? I didn't know 1070 were that big, thought that they were around the same size as 1060's
The 3 fan versions are the same as the 6800 basically.
TechPowerUp says they're both 267mm (10.5 inches), which is suspiciously exact.
https://www.techpowerup.com/gpu-specs/radeon-rx-6800.c3713#:~:text=Radeon RX 6800 is connected,launch was 579 US Dollars.
https://www.techpowerup.com/gpu-specs/geforce-gtx-1070.c2840#:~:text=GeForce GTX 1070 is connected,launch was 379 US Dollars.
Bye 1070 and hello team red. : r/Amd
OnePlus Ecosystem:
Other Tech:
13 minutes ago, Dedayog said:
Good to know, thanks for the info
