Multi Monitor Setup
StephenHolts
Hi Everyone.
Hoping someone can assist.
I have the below setup.
PC Plugged into TV via HDMI
PC Plugged into Monitor in Room Via Display Port
PC Plugged into AV Receiver Via HDMi for Audio
Pc Sees all 3 devices as as screens.
What i want to find out, is there software that will allow me to have a shortcut key set so i can choose how the monitors are setup.
For example i want to have a button i can push that when i want to game on the monitor in the room, i can push and it will disable the TV and Av receiver.
Then if i want to game on my TV, i can push the button and it will disable the Monitor and enable the TV and AV Receiver.
7 minutes ago, StephenHolts said:
Hi Everyone.
Why not just use the built in windows settings?
I edit my messages more than not –
Probably some dude on the internet
Does windows have a Way to Assign a Hotkey to enable and disable specific monitors?
Hit Win-P and see if it does what you want.
