Pc wont turn on after overclock
I've got a ryzen 5 1600x , 16gb ram ddr4 2400mhz , radeon rx 6650xt , and a 600w power supply,
I tried to overclock my cpu , to around 3.9ghz from 3.6 , upped the voltage to 1.375 , and the ram voltage a bit , i did not change anything else .
I saved settings and got into windows , the pc stopped when i opened opera, now it won't turn on , i tried to turn it on with 1 ram stick instead of two , got my gpu out , and even tried to reset my bios , got the motherboard battery out and touched the cmos pins with a screwdriver , when i press the power button , the case fans try to spin but stop instantly .
