Rather low FPS in Fortnite, although my Specs should be sufficient :/
Yeah so i experience bad fps drops and generally low fps with performance settings. I have a 3080ti + my oc i7 8700k which is having heavy loads of 4-5/6 cores beeing maxed out.
Idk why thats hapeniong because my friend, with a far worse pc is having 3 or 4 times more fps.
Thx
Thx
Whats your friends PC specs?
Are you running the same resolution?
what kind of specs does the "far worse PC" have?
current PC:
PC configs I used before:
19 hours ago, Luke Bradley said:
Always have to ask this in these kinds of threads, is your monitor plugged into your GPU and not your motherboard?
Just because I play forntite doesn mean im a retard...
 1050ti i5 8600k
and have you tried directx11 and directx12 mode on low settings or is that worse?
I probably don't need to ask if you have vsync turned off, but how about HDD or SSD drive used for Fortnite?
what about RAM? does your friend have faster RAM?
should I be asking if your graphics drivers are up to date? probably not right?
current PC:
Newest drivers, on my boot m.2  idk abt ram and i only tried direct x 11 Vsync is off atm and i didnt experience any better fps than 50 or 60 even with my monitor set to 165hz
how's GPU and CPU utilization and Temps during gaming? is only Fortnite underperforming for a 30series GPU or other games too?
current PC:
Gpu barely used, cpu kinda tho low temps in the 50s and no wz too
how's the PSU?
current PC:
20 hours ago, podkall said:
how's the PSU?
I have the corsair 1000 Watts One, i think that is enough right? Dont know how to check and dont have the device that you put between ur PSU and the Outlet.
no need, 1000W sounds enough, especially if it's the RM model, or if it's not too old
is the GPU new/second-hand bought, and did the fps drops started happening from the start, or suddenly, or after some change in the PC?
current PC:
Its my dads old card, and yes it was that bad since the start.
was it bad in dad's pc too?
current PC:
No I think everything was good for him there also is no gpu usage (5-10%)
maybe make a new post, that you have low fps and low gpu usage, and include details like the GPU worked fine but as soon as you got it you got performance issues full specs and all the things you tried to fixing it like re-installing probably (if you did)
current PC:
