Can I Permanently Tape Down My Graphics Card Fan?
SkullDood
Hi all,
I recently made a permanent Minecraft server using old PC parts. Everything works great, except the GPU fan is driving me insane. It's a ATI FirePro V4800 1 GB and the fan sounds like a jackhammer. I can hear it across the room through closed doors.
I'm sure there are ways to deal with this that are more hands on but I'm looking for brevity here. I taped it down and left it overnight and HWINFO reported the temps never went over 49c. The case is fairly well ventilated.
I'm most likely not going to use or touch this outside of the server so the GPU should pretty much never be under load.
My anxiety got the better of me and I'm wondering if there's the possibility of serious failure if the fan is left taped down.
I don't know how exactly you are taping it down, but the adhesive on that tape will eventually stop working. If you want to embrace the jank, at least use cable ties.
Qoute my reply if you want me to answer back.
Can't you just unplug the fan from the fan header on its pcb?
CPU : Ryzen 7 7800X3D @ -18mv all core except -13mv on Core 5 because its a pig.
CPU Cooler : Deepcool AK620 Zero Dark
Mobo : MSI B650M-A Wifi MATX
Ram : 32GB (2X16GB) Corsair Vengeance DDR5 6000MHZ CL34
GPU : Reference Design RX7900XT sold by Saphire running at 1050MV undervolt and +15% PL (355w)
Storage : 1TB WD SN770 + 2TB Samsung 970 Evo
PSU : Corsair HX750w Platinum
Case : Asus Prime AP201 All Mesh MATX
Case Fans : Arctic p12's everywhere i can fit them in , 7 In total.
Monitor : LG 27GP850-B.BEK 1440p Nano IPS 180Hz
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
Which old parts? If the CPU has an iGPU, you could simply remove the discrete GPU and use that one instead.
