Error lights on motherboard
Hsxan
Okay, I’ve gotten my pc to power on, but there is no video output. I get these error lights, what should I do?
(B450 AORUS M micro atx)
Rest of your components are?
cpu: Ryzen 7 2700x
Gpu: rx5700xt
Ram: 16gig 2666
Psu: thermal take smart 700 watt
FullSizeRender.MOV
These are not really error lights. They show you which part of POST you are on. If it gets stuck on one light, that's where you start troubleshooting. From your video, it doesn't look like it gets stuck. It gets to Boot and then it shuts down?
It gets to boot and everything stays on but there is nothing showing up on my monitor, I don’t boot into bios or anything
Oh, if the lights turn off and the machine is still on then it should be done with POST and the lights are no longer relevant. Have you made sure that your monitor is connected to the GPU and not motherboard? That CPU doesn't have an iGPU so the motherboard ports don't work. The last thing to test, the GPU, is a bit more tricky as you don't have a GPU so you would have to use a different one to test with.
Make sure the monitor is connected to the bottom ports.
New Gaming PC, Beeping in set up? | PCSPECIALIST
