Pc not performing at its best.
NouGKou
Go to solution Solved by NouGKou,
5 hours ago, OddOod said:
What FPS are you getting in these games?
What are your speeds and temps at those times?
Valorant seems to be running at like 120-150. While league late game mostly keeps dropping lower than 90-100
Hi. I have a PC that is currently (gaming-wise) performing lower than what I would expect. On youtube anyone with this build(or anything close to this build) gets an avg fps of +50 or more than what i do( we re talking about usual e-sports titles LoL Valorant etc). I have no thermal throttling of any way. No errors of any sort. Updated drivers, and yet I still get significantly less than any build with the same GPU on any youtube Video.
Specs : Ryzen 5 2600
6650XT GIGABYTE
16GB 3000(currently at 2666)
500NVMe kingston SA2000
730W PSU
https://www.userbenchmark.com/UserRun/66307885 I even did this and it says its running ok...are the youtube numbers inaccurate or not to be trusted? Or am i doing something wrong?
Thanks in advance
5950X/3080Ti primary rig  |  1920X/1070Ti Unraid for dockers  |  200TB TrueNAS w/ 1:1 backup
5 hours ago, NikolakiH said:
Ryzen is pretty memory sensitive. Why did you under-clock your memory?
I did not..i have the LPX 3000 and 2666 is the best I can get so far on this Mobo
The low memory frequency could probably explain some of that performance difference. Back when I had a r5 2600 I think I got around 180-200 fps in Valorant with a tuned 3000 cl18 kit.
I will give it a try. Thank you my man
