Which Motherboard Should I Go For With My PC Components.
I found out from a post I made earlier that my current motherboard (Gigabyte A320M-S2H) can't handle my Ryzen 9 5900x that I recently upgraded to. I tried figuring out if I could undervolt or underclock my CPU to get more stability, since I am stuttering in games quite often; however the A320 chipset can't overclock or underclock in BIOS, or even using Ryzen Master.
So what motherboard should I replace my old one with? I don't want anything expensive but around $130 USD would be nice. Built in WiFi would be nice but not necessary, since I have a USB Wireless Adapter.
So here are my PC components:
CPU: Ryzen 9 5900x
GPU: RTX 3070
RAM: Corsair Vengeance 3600MHz (2x16GB)
PSU: Corsair RM 750W 80+ Gold
Storage: 1 x 1 TB M.2 NVME SSD, 1 x 1 TB SATA SSD
Case: NZXT H5 FLOW ATX MID-TOWER CASE
12 minutes ago, Sjaakie said:
Could be worthwhile to get figure out where the stuttering comes from. What is your cinebech score? Any throttling on the cpu?
Otherwise the https://pcpartpicker.com/product/YhtLrH/gigabyte-b550m-aorus-elite-ax-micro-atx-am4-motherboard-b550m-aorus-elite-ax is nice and your budget and with wifi.
This, but the ATX version not the micro.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Lian Li Lancool II Mesh C / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Yeah the CPU is throttling to like 0.3GHz to 2.1GHz all the time and it’s only at 60 degrees Celsius. Many others were saying that my motherboard is the issue here and it isn’t delivering enough power to my CPU. Also I tried underclocking my CPU through BIOS but it didn’t do anything other than change the number on Task Manager and in Cinebench R24. Here is one from GeekBench 5: https://browser.geekbench.com/v5/cpu/22021139 D442B1DA-C4B1-40FB-94CD-22E1ED34C4A5.thumb.jpeg.76c0ff5d8218f485a94aacbcdcf2c2fd.jpeg 22834566-2366-4204-8FC7-9B9EF0027F1A.thumb.jpeg.309c83abdb3f230301be9f862d7821eb.jpeg
Could be power throttling, maybe power limits can be increased in the bios.
But probably the board is just too low spec for a 5900x indeed.
