Budget (including currency): $1500 USD (not including shipping and taxes)
Country: United States
Games, programs or workloads that it will be used for: Light gaming and streaming
I am making a gaming and streaming PC for a friend and I created a PCPartPicker list and just wanted someone to double check it and see if there are any things I can do to make it better for the price.
https://pcpartpicker.com/list/8WVD7R
I usually buy an OEM key for windows on a key site, and download the .iso-file from microsofts website. It is so much cheaper. I am from the EU, so I don't know which sites are available in the US, but I usually shop at MMOGA for 10-20€ instead of ~100€.
If you just included the OS for transparency, just ignore this xD
3 hours ago, LinkRuelz13 said:
Light gaming
How light? Also 4060Ti is just not worth it, i would bump up to 4070.
PCPartPicker Part List
CPU: AMD Ryzen 7 7700 3.6 GHz 8-Core Processor  ($328.99 @ Amazon)
Motherboard: Gigabyte B650 GAMING X AX ATX AM5 Motherboard  ($189.99 @ Amazon)
Memory: G.Skill Flare X5 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($104.99 @ Amazon)
Storage: Silicon Power UD85 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($83.97 @ Amazon)
Video Card: Zotac Twin Edge GeForce RTX 4070 12 GB Video Card  ($644.00 @ Amazon)
Case: Deepcool CC560 ATX Mid Tower Case  ($75.54 @ Amazon)
Power Supply: MSI MPG A850G PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($114.99 @ Amazon)
Total: $1542.47
Generated by PCPartPicker 2023-12-05 01:00 EST-0500
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
Total: $1542.47
He's mostly a console gamer so the emphasis is more on streaming and recording his games but it needs to be powerful to run some semi-modern titles at medium to high setting while still being able to stream at a decent quality. Also at this price point do you think it would be better to go Intel or AMD, he doesn't have a preference.
Yeah it was mostly just for transparency but I'll keep that in mind, thanks!
Either-or. If getting 14600K or 13600 non K with a good B760 board (refer to this review for example, the quality should still be in parity between these 2 gen) and a Peerless Assassin 120 instead of just stock cooler would be cheaper, then go for that.
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($199.00 @ B&H)
CPU Cooler: Thermalright Assassin X 120 Refined SE 66.17 CFM CPU Cooler  ($17.89 @ Amazon)
Motherboard: ASRock B650M-H/M.2+ Micro ATX AM5 Motherboard  ($109.99 @ Amazon)
Storage: Silicon Power UD85 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($84.79 @ Amazon)
Video Card: Gigabyte WINDFORCE OC GeForce RTX 4070 Ti 12 GB Video Card  ($782.20 @ Amazon)
Case: Phanteks Eclipse G300A (3 Fan) ATX Mid Tower Case  ($54.99 @ Newegg)
Power Supply: SeaSonic FOCUS Plus 750 Gold 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($95.00 @ Amazon)
Total: $1448.85
Generated by PCPartPicker 2023-12-05 14:41 EST-0500
Just use gpu for streaming and much better experience.
