!HELP! Terrible graphics on RX 6800 XT
dejankli
Hello,
I have an issue with my graphics card. When I play games the image quality is poor, it looks like there's a grain/pixelated filter over it. Does anyone know how to help?
I've attached an image bellow as an example in Forza Horizon 5.
Edited by dejankli
Your screenshot is so low-resolution it's quite hard to see the problem.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | PowerColor Red Devil RX 6900 XT | 4x8GB Crucial Ballistix 3600mt/s CL16
If that image is a screenshot at the resolution of the game, you're playing at a very low resolution.
What is the resolution set to in Windows and in game?
It's set to 1920 x 1080, on both.
No, that's the "grainy filter" I'm talking about.
Are you reducing the resolution of the images before posting them, or is that just the resolution you get when you do a screenshot? Because those images are not 1080p.
Can you show us the game settings?
Your first screenshot is 1357x439.
That's the resolution I get when I take a screenshot
Edited by dejankli
Also, my VRAM Clock Speed is a little over 1900 MHz even in idle, is that normal?
Edited by dejankli
Does Forza Horizon 5 have an option for film grain or something?
Is resolution scaling disabled?
1 minute ago, YoungBlade said:
Do you have any AMD driver features enabled, like AMD Boost?
I put everything on off
Yes it's disabled and no FH5 doesn't have any of those settings..
Did you recently upgrade to this graphics card? If so, did you use DDU in Safe Mode to remove the old drivers?
I did come from an rtx 2060 yes, and I used DDU in Safe Mode.
  • 1 month later...
On 12/4/2023 at 8:45 AM, dejankli said:
Hello,
did you fix it? having same issue
