Does anyone have closeup of what cables should be plugged in right spots
Reez12
i wanna see a clear photo of what cables should be plugged in on motherboard so I can make sure mines are right
You should check the manual for the motherboard and the components. Depending on what you are connecting it could have some limitations that vary from one motherboard to another.
CPU: AMD Ryzen 9 3950X   Motherboard: MSI X570 Gaming Edge Wifi   Case: Deepcool Maxtrexx 70   GPU: RTX 3090   RAM: Corsair Vengeance LPX 3x16GB 3200 MHz   PSU: Super Flower 850W
Tons of YT videos out there, as well as markings on the cables, PSU and motherboard.
Not to mention manuals.
Have you watched any build guides at all?
24pin goes in 24pin slot.  Others are keyed to fit their stuff.  USB power only fits USB socket, etc.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Lian Li Lancool II Mesh C / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Honestly the hardest part is connecting the power button and LED, but its not going to damage anything if you get those wrong.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz) WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz)
Switches: Netgear MS510TXUP, Netgear MS510TXPP, Netgear GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
7 minutes ago, PinballGamingYT said:
What mother board do you have?
I got rog strix b550-f
Did it come with a manual?
OnePlus:
Other Tech:
My PC Specs: (expand to view)
Main Gaming Machine
CPU: Intel Core i7-10700K - OC to 5 GHz All Cores
CPU Cooler: Corsair iCUE H115i RGB Pro XT (Front Mounted AIO)
Motherboard: Asus TUF GAMING Z490-PLUS (WI-FI)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600
Storage: Intel 665p 1 TB M.2-2280 NVME SSD (x2)
Video Card: Zotac RTX 3070 8 GB GAMING Twin Edge OC
Power Supply: Corsair RM850 850W
Case: Corsair 4000D Airflow
Case Fan 120mm: Noctua F12 PWM 54.97 CFM 120 mm (x1)
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x4)
Monitor Main: Asus VG278QR 27.0" 1920x1080 165 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
5 minutes ago, Hinjima said:
HE was supposed to do that!  Stop enabling 😛
OnePlus:
Other Tech:
Haha, he seems quite lost sadly.  I had to help =/ 😛
Thanks for helping I’m understanding better now
