What color is light supposed to stay on or does it change
Reez12
I built a pc and the motherboard light changes to red white and orange idk what it means
HI,
red light on your motherboard means internal hardware is either plugged-in incorrectly or not working.
When the white light is illuminated on the motherboard, it serves as an indication that there may be underlying problems affecting either the graphics card itself or the connection between the graphics card and the display.
motherboard showing orange light?
Insufficient or faulty power supplies may trigger voltage fluctuations, causing the orange light to come on. Always choose a good power supply to protect against any type of power surge that could damage the motherboard and trigger the error light.
2 minutes ago, ET_Explorer said:
HI,
Wait is it true that if u don’t got a gpu your usb is useless on motherboard
No, where on earth did you hear that?
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz) WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz)
Switches: Netgear MS510TXUP, Netgear MS510TXPP, Netgear GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
Somone told me that like 1 month ago they keep making me like scared cause like my pc I just built I wanna make sure it works I just need to buy a graphics card
Also of the debug LED turns white and stays white, but the PC is working fine, don't worry about it.  Mine did that a few times, its merely there as an indication of what might be at fault if you have problems.  If you aren't having problems it can be ignored as the BIOS seems to sometimes glitch and forget to turn it off.
Just now, Alex Atkin UK said:
Also of the debug LED turns white and stays white, but the PC is working fine, don't worry about it.  Mine did that a few times, its merely there as an indication of what might be at fault if you have problems, if you aren't having problems it can be ignored as the BIOS seems to sometimes glitch and forget to turn it off.
I hope my pc will boot into bios when I still the gpu I got like a discrete cpu Ryzen 4500 4000 seris
I would suggest asking an adult to help you out.  If you aren't sure your components and are easily convinced things like a GPU/USB relationship...
I think you may need help/guidance.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Lian Li Lancool II Mesh C / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
