FPS going bad after some seconds after startup
TheYTB
So i need a nerdy guy to tell me whats going on.
I have my laptop a Acer Aspire V3-571G from 2013
The components are :
Intel Pentium B960 2.20Ghz 2C 2T
Nvidia Geforce GT630M 1GB Vram
DDR3
6GB Ram DDR3-1333MHz
Operating sistem: Ghostspectre V13 Compact 22H2
Idle temps after running for some time are :
CPU:76°C avg
GPU:76°C avg
SSD:47°C
Idle temps after shutdown and letting it cool :
CPU:57°C
GPU:50°C
SSD:26°C
 But when i start a game its game over for temps
73°C CPU
69°C GPU (no joke)
And it goes to the temps specified first while gaming
When i start the laptop (plugged in) i go into subnautica for example i have a solid 40fps but after 20 seconds it drops to 15fps
Same with other games like minecraft survival with optifine 60 fps and than 20-30 fps
The gpu is using the latest driver 391.35 i think it was
The bios is old so i don't have XMP or other advanced features so basicly its useless
I don't wanna switch to a gaming laptop for the moment
The laptop is externaly colled by a 1 fan cooler
Always plugged in cause the battery is dead (The battery is still in)
2022 was the last time that it was cleaned and thermal paste put everywhere.
Cause of custom os and optimizations i have no blootware
104 Procceses
1552
Uptime only 10 minutes to heat up
1.8 GB windows using
Half of procceses are windows the rest is nvidia ,ghub,realtek and others
I hope i get a fast response cause i've been playing games a lot and i wanted to fix this for a long time
77°C cpu while gaming i think is not bad but 85°C and above it would be
That cpu has a junction temperature of only 85 °C.
CPUs usually start thermal throttling before they reach their maximum allowed temperature.
76 °C is very likely to be the limit that the BIOS is allowing. It looks like another clean-out will be necessary.
Good luck.
Qoute my reply if you want me to answer back.
