Pc works, but not works (i think power related issue)
Shortboi
Go to solution Solved by --SID--,
First remove the extensions because they often cause a lot of issues.
2nd remove the GPU and connect the monitor to the motherboard. Reset CMOS and try to power up again.
Hello, I just built my first Gaming PC but my PC doesn't work.
At first, the PC boots with an CPU debug light on the motherboard. I checked the cable, but after powering it on again, it was the same again
After a little bit of time, my rgb's went off(exept for my RAM rgb). So I pressed the power button to turn the pc off.
And then, when I tried to turn it on again, it just did nothing. So no rgb and no fan spin.
Just one thing. Sometimes I get a split second of fan spin(only case fans(Antec AX61 Elite)) and a light on my gpu (Inno3d RTX 3070)
I don't know if it will help, but here are my specs:
Intel core i5 13500
deepcool AG400 BK
msi pro b760-p wifi ddr4
antec ax61 elite
corsair vengeance rgb pro (3600 mhz cl18)
inno3d rtx 3070
asiahorse cable extensions
antec high current gamer 850w 80+ bronze
I live in the netherlands if it helps
This could be an overheating issue. Check your cpu if anything is wrong
No overheating issue, after solving saw cpu 20c idle
Was a problem with my cpu extension cable. Thans for the help!
