New PC and my front Fans aren't working
BowlofNails
Everything in my pc works fine besides my front fans. I only have one fan port besides the cpu fan(motherboard: GIGABYTE B450M DS3H). I connected a fan hub to the system fan port and the 2 case fans, top fan, and back fan into it but only the top and back fans work. How can I fix this
I see 4 fan headers.
Edit : Oh, that's not your motherboard, but why include it then ?
Are your front fans turning freely ?
Edited by leclod
I'm willing to swim against the current.
Is this a powered fan hub?
Primary PC:
If you have a fan hub and 2 out of 4 fans work, there’s something going on with the hub. Try switching ports between the front and top/back. If the fronts start working you have a defective fan hub.
If you mean plugged in somwhere yes It's pluged into the motherboard
My bad thought that was the right one. They turn if i (after unplugging everything) open the case and move them with my hands
20 hours ago, emosun said:
did you plug the front fans into something
It's plugged into the motherboard
no, does it have its own power, like a SATA power connector?
Primary PC:
I dont believe so
1 hour ago, BowlofNails said:
I dont believe so
If the fan hub doesn't have external power, it may not be sufficient for 4 whole fans. You might consider replacing it with one 2-fan splitter, and then get a 3-fan splitter to couple off your other fan header since you only have 2 headers
Primary PC:
