Motherboard 5V_ARGB header
Go to solution Solved by Poinkachu,
23 minutes ago, Sisu5700x said:
Hello, im building my first pc and im buying the DeepCool FC120 fans. They interconnect and out of the last fan you have a cable coming out that has 3 ends. Sata power, Fan header cable and 5V_ARGB cable. On my gigabyte b550 gaming x v2 motherbaord there is a header called D_LED1. does the 5V_ARGB cable plug into that or do i have to buy non rgb fans
D_LED1 is a 5v ARGB header
If at the very least the 5v argb connector looks somewhat like this, then yes, you can plug it in there :
Refresh before you reply
