Is these 7900x temps normal?
yung_fresh
So i rencently build a 7900x system with a kranek elite 360mm aio and it sits in bios a 50c aand at 70 c at 20% usage and 95c at 100% is these temps normal? i have isntalled the latest bios and drivers.
For stock, yes. Ensuring the cooler has adequate contact with enough thermal paste and being in a cooler ambient environment can improve things. My old 7900x with an air cooler idled around 45 and would see 92-93c in Cinebench when stock. That was with an AK620 air cooler at the time, but it was in a Fractal Torrent with phenomenal airflow. At completely stock, 95c is the temperature target so its doing what its supposed to do. Ensure your AIO's pump is set to 100%.
Luckily though with Curve Optimizer undervolting and setting a temp limit, you can bring this down and still be faster than stock.
70 degrees while drawing 50-60W rarely happens for me with a Mugen 5... what case are you using? Do you notice any strange sounds coming from the AIO?
the pc guy
It's a bit high imo, the kraken is a good cooler
Check paste and mounting pressure
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
Yes, the CPU will do everything it can to get to 95 C due to how it's designed to run. Better cooling will give you slightly higher clock speeds but you'll still be touching 95 C for stock settings.
